uncap upload speed
- uncap upload speed
uncap upload speed
03-12-2012 10:48 AM
What information do you need from me to uncap my upload speed?
Additionally, my 2wire router is indicating there is a rate cap on my line of 5549kbps, and I am on ADSL2+. Please could you confirm why this is?
Message 1 of 7
(1,110 Views)
6 REPLIES 6
Re: uncap upload speed
03-12-2012 2:31 PM
We don't need any information besides knowing that you'd like your upload uncapping
Regarding the download speed, this depends on a number of factors but mostly the length of your phone line between your premises and the exchange. In general, the longer the line the slower the speed.
Hope that helps explain, if you post back confirming that you'd like the upload uncapping we'll get the order placed for you.
Message 2 of 7
(525 Views)
03-12-2012 2:38 PM
If you post the stats from your router we may be able to answer the other question - info needed is attenuation, noise margin and speeds
Message 3 of 7
(525 Views)
03-12-2012 3:22 PM
Hi, thanks for your replies.
Yes, i would like my upload uncapping. What can i expect it to rise to and will it cost anything extra?
Downstream attenuation at 300khz - 41.8 db down, 24.7db up.........Any ideas how this could be lowered, if at all?
Noise margin - 6.1db down, 5.8db up
Speed - 6593 kbs up, 784kbs down
Thanks both for your help
Will
Will
Message 4 of 7
(525 Views)
03-12-2012 3:28 PM
According to that your upstream is already uncapped
Given your downstream speed of 6593kbps and hence IP profile 5815 kbps where do you get 5549kbps from or is it a speed test result
Regarding your attenuation that is a function of your distance from the exchange (cable length) and you can't change it
Message 5 of 7
(525 Views)
03-12-2012 3:42 PM
It is a figure listed as 'max rate' and further down the same figure is listed as 'rate cap' on my router. I have checked again and it is still saying the same thing, which is odd, it doesn't appear to relate to anything.
I have something else listed as 'uncanceled echo' which is -18.3db. Is that good or bad?
Message 6 of 7
(525 Views)
03-12-2012 3:59 PM
Quote from: Oldjim Regarding your attenuation that is a function of your distance from the exchange (cable length) and you can't change it
Not totally true, there is something you can do but it would be a lot of expense and worry and you'd need the help of someone like these guys: http://www.davisbuildingmovers.com/
It would probably be cheaper to move house.
Message 7 of 7
(525 Views)
