ADSL2+ Annex M Trial
- Re: ADSL2+ Annex M Trial
22-01-2010 1:09 PM
Edit: Forget it for now. Phone line is in a bad state. BT dragging their feet over sending an engineer out. If I'm really lucky, then maybe I'll have a working line after 8th Feb.
04-02-2010 12:37 PM
I'll be using a ZyXEL P-660R-D1
04-02-2010 3:30 PM
Plusnet Technology
04-02-2010 8:04 PM
Can I reasonably assume that participation in the DLM trial would not necessarily prevent taking part in this as well?
Thanks,
Alastair.
04-02-2010 8:56 PM
Plusnet Technology
04-02-2010 9:01 PM
04-02-2010 10:05 PM
Cheers dave
B.
05-02-2010 10:10 AM
If you have any spaces coming up I'm happy to be added. Currently using a netgear DG834G but do have the thomson available for use.
Forum Moderator and Customer
05-02-2010 3:55 PM
Mav - no places left at the moment unfortunately, if there are later on I'll keep you and the others that have asked in mind.
Plusnet Technology
05-02-2010 5:43 PM
soft360lap1
jamesd
The remaining lines are made up of staff, test lines and customers identified by our business support team. The trial is due to start around 8th March, we won't move all the lines on day 1, they'll moved across a couple at a time. I'll be in touch a bit nearer the time to arrange to send out a router and when we'll switch you across.
Plusnet Technology
06-02-2010 12:36 AM
08-02-2010 12:45 PM
Plusnet Technology
08-02-2010 5:50 PM
15-04-2010 1:17 PM
I'm currently on 21CN ADSL 2+
I've got a Billion 7800 Router which supports Annex M.
Regards,
Rob.
15-04-2010 1:22 PM
http://www.thinkbroadband.com/news/4144-how-fast-is-your-broadband-router.html
