ADSL drops when phone used
- ADSL drops when phone used
10-10-2014 10:38 AM
If someone phones or we phone out the internet connection drops and reconnects at a much lower speed. Tried filters etc.
Message 1 of 3
(539 Views)
2 REPLIES 2
Re: ADSL drops when phone used
10-10-2014 11:00 AM
Are you on ADSL or the fibre FTTC service? Has this been going on a long time or is it a new issue?
Message 2 of 3
(334 Views)
10-10-2014 11:44 AM
First thing is to check where the fault lies although it is more than likely a line or line card fault
Disconnect the phone from the line and connect the router to the test socket
Phone in using your mobile - does it disconnect
Message 3 of 3
(334 Views)
