ADSL Speeds Issues
Legend
Fixes: 255
Re: ADSL Speeds Issues
Sorry to hear of your multiple troubles, Keith. From my quick look at the D7800 guide last night, your failure to find that really useful info doesn't surprise me - they seem to be removing useful features on new gear, while introducing many that most users don't want, or need.Crazy.
Yes, the 2704N will give that data, thankfully.
Is it just you that's down, do you know, or is it an area-wide thing? If you give your phone area code, I could check?
keithdwilliams
I think its just us, but i dont know for sure... I'll ask about, it's a small village / hamlet so that shouldnt be a difficult to find out.
The area code is 01389, but that covers a significant physical area, of which we are a very small section.
Legend
Fixes: 255
No area-wide reports showing, so it probably is just you - sorry.
tinytaco
Fixes: 29
Morning @keithdwilliams
I am sorry to hear about the loss of connection, I can confirm that we have located an external fault on your line that is impacting your services. Our Suppliers have advised an estimated response time of 08/02/21 23:59:59, I have logged the fault on your account here to be reviewed by the Faults Team following that timescale Smiley
 Noor
Mustrum
Fixes: 77
@jab1  Although Netgear GUI information is limited, there is more info than most people know what to do with if you telnet to them.
Some would say a D7800 is overkill for a long ADSL line, but each to their own.
@keithdwilliams  you really need to get your phone line sorted before trying to get higher speeds on broadband.
keithdwilliams
thanks @tinytaco
i dont mean to sound precocious, but, the 8th is 4 days away?! is that the longest i would wait?
Legend
Fixes: 255
OK @Mustrum , I'll take your word for that - re the information, but I recall on my DG834 you didn't have telnet - it was just there - easy to access and easy to understand. These days, it seems that basic data is hidden, as though they don't want you to be able to easily find it.
Makes it hard to help yourself, if you are capable, or others, if they need guidance.
tinytaco
Fixes: 29
Hi @keithdwilliams it is the longest you'll have to wait for an engineer to respond to the job, they tend to come out before that 😊(don't hold me to that though, ha! 🤣)
 Noor
keithdwilliams
@Mustrum its not a new router, and was bought when the line was shorter - well, for a different location. it has worked very well until this week! i did manage to get into telnet, but i couldn';t any description of the commands the CLI uses to output anything meaningful - is there a description somewhere? its a BusyBox OS - i think - i'd be very interested in seeing something. when we're back up and running!
as for the line, there's a fault... when we sort that, i'll worry about the rest!
keithdwilliams
thanks @tinytaco
Mustrum
Fixes: 77
@keithdwilliams  I have a D7000 which i have been very pleased with, I use DSLstats to monitor it, and chose this model over the D7800 as I knew DSLstats worked. AS such I have to look up commands if i want to use them, but the basic output from it is:
adslctl info --stats
adslctl: ADSL driver and PHY status
Status: Showtime
Last Retrain Reason: 0
Last initialization procedure status: 0
Max: Upstream rate = 24429 Kbps, Downstream rate = 76771 Kbps
Bearer: 0, Upstream rate = 20000 Kbps, Downstream rate = 75335 Kbps
Link Power State: L0
Mode: VDSL2 Annex B
VDSL2 Profile: Profile 17a
TPS-TC: PTM Mode(0x0)
Trellis: U:ON /D:ON
Line Status: No Defect
Training Status: Showtime
Down Up
SNR (dB): 6.3 9.2
Attn(dB): 8.6 0.0
Pwr(dBm): -9.0 -9.0
VDSL2 framing
Bearer 0
MSGc: 18 150
B: 239 236
M: 1 1
T: 22 5
R: 0 16
S: 0.1014 0.3771
L: 18936 5410
😧 1 1
I: 240 255
N: 240 255
Counters
Bearer 0
OHF: 589697539 87069
OHFErr: 4120 2634
RS: 0 3861529
RSCorr: 0 26746
RSUnCorr: 0 0
Bearer 0
HEC: 12965 0
OCD: 101 0
LCD: 101 0
Total Cells: 1753079239 0
Data Cells: 771018414 0
Drop Cells: 0
Bit Errors: 0 0
ES: 1569 1595
SES: 2 0
UAS: 27 27
AS: 990390
Bearer 0
INP: 0.00 0.00
INPRein: 0.00 0.00
delay: 0 0
PER: 1.67 6.15
OR: 114.31 202.87
AgR: 75449.27 20203.27
Bitswap: 2254/2462 515/516
Total time = 11 days 11 hours 6 min 57 sec
FEC: 0 26746
CRC: 4120 2634
ES: 1569 1595
SES: 2 0
UAS: 27 27
LOS: 0 0
LOF: 0 0
LOM: 0 0
Retr: 0
Latest 15 minutes time = 6 min 57 sec
FEC: 0 6
CRC: 0 1
ES: 0 1
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Retr: 0
Previous 15 minutes time = 15 min 0 sec
FEC: 0 9
CRC: 23 1
ES: 3 1
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Retr: N/A
Latest 1 day time = 11 hours 6 min 57 sec
FEC: 0 799
CRC: 95 95
ES: 42 56
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Retr: 0
Previous 1 day time = 24 hours 0 sec
FEC: 0 1442
CRC: 167 154
ES: 122 123
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Retr: 0
Since Link time = 11 days 11 hours 6 min 29 sec
FEC: 0 26746
CRC: 4120 2634
ES: 1569 1595
SES: 2 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Retr: 0
NTR: mipsCntAtNtr=0 ncoCntAtNtr=0
keithdwilliams
@tinytaco i think BT, or their associate company, tried to call the landline - which is almost entirely dead now - and i missed them. I have no way to call them back or contact them - do i need to? Or will they come back to me?
Legend
Fixes: 255
@keithdwilliams Do you know the number that called you? If so, call it back on your mobile?
keithdwilliams
Company called Inter-act... but number goes to a recorded message with no means of contact.
I guess patience is the name of the game.
Legend
Fixes: 255
OK Keith - don't know them, but I SUPPOSE they could be BT subcontractors.
