A Chronicle of My Migration and Problems
- A Chronicle of My Migration and Problems
Re: A Chronicle of My Migration and Problems
21-05-2009 1:20 AM
Still, I'm happy with that - at least it's a proven release.
22-05-2009 1:51 AM
Although the label on the router says V4, when I've installed this and had a look at the frirmware version it says V5 something or other.
However, the Netgear router is now up and running. (well, for the past hour or so)
I have just managed to get RouterStats running too (could only use RouterStats light on the Linksys)
Now it might just be me, and it is early days yet, but the Linksys was showing a NM of about 10 before I switched it off to fit the Netgear.
RouterStats is showing the Netgear with a down NM of 6.3 to 6.5 at the moment and an up of 6.3
The sync speed has not changed much though - showing as 9726 instead of 9725
The Linksys was also showing (according to RouterStats Lite) fluctuations of NM between 8 and 11, whereas, at the moment the Netgear is showing marginal fluctautions in the order of of 0.1 or 0.2 as indicated above.
Is there anything else that I can get access to now that I have got the full version of Routerstats installed and running?
Let's leave this for now - it's nearly 2am and I have to get up for work in the morning.
Graham
22-05-2009 5:20 PM
Onto Routerstats. As you seem to have found, it is easy to configure it for this router. I think it automatically detects the Version on most pages, but occasionally it is necessary to select V4. You should be able to access the more hidden information by enabling Routerstats' telnet interface. This is done via the Experimental Settings tab on the Configuration -> Telnet tab (make sure you mark the V4 radio button on this page). A Telnet Router tab will then appear on the main display page. The various tabs that gives should include one showing the Bits and SNR per Tone, which can be illuminating.
One of the tabs is for Setting Target SNR; tinker with that at your peril. From the experience posted by others I think it is fair to say that doing so confuses the DLM and it can take a long time for it to forgive your indiscretion and react normally.
In fact leaving things alone is my suggestion for the moment, let's see what the DLM makes of the new configuration. It would be interesting to see the full router stats from the Netgear and SNR history daytime and after dark.
David
22-05-2009 10:27 PM
Switched on PC tonight to see that down sync was down to 5689 and originally the NM was 6.
Just after 10.00 pm the NM shot up to 19.5 and it is currently hovering around 19.
I've also got DMT installed and working, so if there's any info hidden in there please let me know what to look for
23-05-2009 1:12 AM
For the moment I think the way forward is to let the DLM get on with its line management activities. Increasing the target noise margin as it has done seems to be part of its logic and before long (can be 7 to 14 days) it should come down again. Looking at the bits/tone plot again would then be useful - a similar shape to the present one could indicate a broadband fault.
I don't think DMT gives more information than Routerstats for the DG834V4, some regard the plots from DMT as easier to read. It's not a program I am very familiar with.
David
23-05-2009 5:54 PM
I guess we wait and see again. (for 3 days the techie said)
The chap from PN who phoned me also said that PN are having many discussions with BT regarding the agressiveness of the DLM and it's slow response to put NM back up. It doesn't sound as if they are getting anywhere, which is strange as BT own PN, (not something that is shouted out in the public domain) so you would have thought that one would co-operate with the other
Maybe it's because it would BT cost such a lot of money to "reprogram" all those DLM's to bring NM up faster, and nothing to do with operating at the best setting?
Anyway, here's the current figures:
24-05-2009 12:45 AM
Noise Margin: 4.3 dB
Connection Rate: 9721 Kbps
Line Attenuation: 32.0 dB
Power: 0.0 dBm
Max Rate: 16016 Kbps
SF: 1642311
SF Errors: 28
Reed Solomon: 1405818428
RS Corrected: 175999
RS Un-Corrected: 838
HEC: 18
Errored Seconds: 18
Severe ES: 0
Interleave Depth: 128
Power: 0.0 dBm
SF: 1642311
SF Errors: 28
HEC: 18
Errored Seconds: 18
Severe ES: 0
24-05-2009 1:03 AM
24-05-2009 9:33 AM
Well here it is as of 9.40 on 24/5:
Noise Margin: 5.3 dB
Power: 0.0 dBm
Max Rate: 16744 Kbps
SF: 3638543
SF Errors: 34
Reed Solomon: 3114592946
RS Corrected: 348552
RS Un-Corrected: 962
HEC: 24
Errored Seconds: 24
Severe ES: 0
Noise Margin: 5.7 dB
Connection Rate: 1220 Kbps
Line Attenuation: 14.8 dB
Power: 13.0 dBm
Max Rate: 1216 Kbps
SF: 3451488
SF Errors: 0
Reed Solomon: 833777
RS Corrected: 0
RS Un-Corrected: 0
HEC: 0
Errored Seconds: 0
Severe ES: 0
Interleave Depth: 4
I have left the PC on all night so that I could get a "bigger picture" of behaviour.
Looking at the plot, it's like watching a bad movie; nothing much happens.
Noise margin dropped about 10 pm from ~6 to ~4.5 and then slowly went down to ~4 at about 2am, then slowly crept back up to ~5 at about 5am. At about 6am it jumped slightly to 5.3 at which is has remained (give or take 0.1) till now. Sync speed 9721.
At one stage Saturday night (8ish?) when I checked the telnet data, the level of down "interleave depth" was a whopping 384 and 64 on up.
As you can see above, it's gone down a fair amount, but I still think 128 for the down is a bit of overkill.
It may be that a down NM of 4 is a bit too low for the line and maybe if it creeps up to 6 then the HEC and other errors will go away.
BTW - Who's this Reed Solomon who's sticking his two-pennorth in?
Graham
25-05-2009 1:12 AM
The present download interleaving depth of 128 is double the usual 64, but maybe implies the system is still coping with noise - probably the reason for your sync speed being lower than it should be at your attenuation and the hollows in the bits/tone plots. Do those look any different now from before?
David
25-05-2009 10:07 AM
But I still don't know what the figure in the router stats is trying to tell me.
The latest (today at 10.05 -ish) tones plot is attached.
Summary:
Noise Margin: 5.2 dB
Power: 0.0 dBm
Max Rate: 16632 Kbps
SF: 9100964
SF Errors: 133
Reed Solomon: 3495458462
RS Corrected: 1120087
RS Un-Corrected: 2596
HEC: 95
Errored Seconds: 96
Severe ES: 0
Noise Margin: 5.5 dB
Power: 13.0 dBm
Max Rate: 1216 Kbps
SF: 8628060
SF Errors: 0
Reed Solomon: 4224360
RS Corrected: 0
RS Un-Corrected: 0
HEC: 0
Errored Seconds: 0
Severe ES: 0
Interleave Depth: 4
25-05-2009 9:53 PM
I have attached one image showing the drops around 1400/1423
Current summary is:
Downstream:
Noise Margin: 4.5 dB
Power: 0.0 dBm
Max Rate: 16132 Kbps
SF: 11734763
SF Errors: 293
Reed Solomon: 1455022828
RS Corrected: 1517013
RS Un-Corrected: 22076
HEC: 233
Errored Seconds: 168
Severe ES: 1
Upstream:
Noise Margin: 6.0 dB
Power: 13.0 dBm
Max Rate: 1224 Kbps
SF: 11124687
SF Errors: 0
Reed Solomon: 2723503
RS Corrected: 0
RS Un-Corrected: 0
HEC: 0
Errored Seconds: 0
Severe ES: 0
Interleave Depth: 4
Download speed is screwed though
Yes, that does say a download speed of 130kbps and an upload speed of 1028kbps
Bt's test also shows a similar result:
Test1 comprises of Best Effort Test: -provides background information.
Your DSL connection rate: 9720 kbps(DOWN-STREAM), 1220 kbps(UP-STREAM)
IP profile for your line is - 8000 kbps
Actual IP throughput achieved during the test was - 83 kbps
Graham
26-05-2009 2:35 AM
I suggest recording the downstream errors, doing a speedtest then recording the downstream errors again. Since there shouldn't be any traffic shaping on HTTP/speedtest data I'm making the assumption that only errors could cause so much slow down.
This "constant sync speed" syndrome seems to be reported by several users - though Asbo has just managed to find the escape door.
David
26-05-2009 9:29 PM
Yes the PN speed profile is still saying 8000.
I tried the before and after test:
Before speed test
Noise Margin: 4.6 dB
Power: 0.0 dBm
Max Rate: 16252 Kbps
SF: 16940614
SF Errors: 439
Reed Solomon: 1616264118
RS Corrected: 2756252
RS Un-Corrected: 26030
HEC: 350
Errored Seconds: 251
Severe ES: 1
After speed test
Power: 0.0 dBm
Max Rate: 16176 Kbps
SF: 16949639
SF Errors: 439
Reed Solomon: 1623989860
RS Corrected: 2757181
HEC: 350
Severe ES: 1
As can be seen there are quite a few RS corrected errors (929) but nothing else logged.
The speed test still gives:
The down NM is still showing as 4.5 and sync speed is 9721 (as above)
Up NM is 6.1 and sync speed 1220.
It's 3 days since I last contacted the techies, so I'm going to pass these figures over to them to have a look at.
Graham
26-05-2009 10:51 PM
David
