9225 kps at Router but only 6400Kps speedtest at computer - Why?
- Re: 9225 kps at Router but only 6400Kps speedtest...
Re: 9225 kps at Router but only 6400Kps speedtest at computer - Why?
25-02-2010 8:54 AM
A week on and profile still stuck at 7000kps. No sign of the engineers correcting the profile .
Still achieving consistant speeds of 9000kps at the router
see below for bt speedtest ( 5mins ago)
Can someone please help sort this out ?
thanks
j
Download speedachieved during the test was - 6268 Kbps
For your connection, the acceptable range of speedsis 600-7150 Kbps.
Additional Information:
Your DSL Connection Rate :9067 Kbps(DOWN-STREAM), 444 Kbps(UP-STREAM)
IP Profile for your line is - 7150 Kbps
The throughput of Best Efforts (BE) classes achieved during the test is - 9.33:28.81:61.85 (SBE:NBE:PBE)
These figures represent the ratio while sententiously passing Sub BE, Normal BE and Priority BE marked traffic.
The results of this test will vary depending on the way your ISP has decided to use these traffic classes.
25-02-2010 1:48 PM
25-02-2010 2:22 PM
j
25-02-2010 2:53 PM
25-02-2010 2:58 PM
04-03-2010 11:45 AM
well above required rate
Can someone monitor and up the IP profile 8000kps
thanks
j
Download speedachieved during the test was - 6339 Kbps
Your DSL Connection Rate :10504 Kbps(DOWN-STREAM), 444 Kbps(UP-STREAM)
IP Profile for your line is - 7000 Kbps
The throughput of Best Efforts (BE) classes achieved during the test is - 15.48:23.08:61.45 (SBE:NBE:PBE)
04-03-2010 12:15 PM
04-03-2010 2:13 PM
j
08-03-2010 2:46 PM
11-03-2010 11:50 AM
still having problems can someone help
Since being raised to 8000kps from 7000kps my connection rate at my modem has reduced from over 10000kps to 7500 kps (not sure why this has occurred)
Consequently my IP profile appears to have dropped from 8000kps to currently 6000kps and im currently achieving around 5300 kps at the computer - well below my rate a week ago
Maybe i should have left my profile as it was at 7000kps.
Can someone explain why this should have occurred and what i can do to raise the connection rate- when raised i initially got well over 8000kps at the computer - this has gradually fallen over the week to the current rate of 5300kps.
thanks in advance
j
Download speedachieved during the test was - 5298 Kbps
Your DSL Connection Rate :7488 Kbps(DOWN-STREAM), 443 Kbps(UP-STREAM)
IP Profile for your line is - 6000 Kbps
The throughput of Best Efforts (BE) classes achieved during the test is - 10.66:22.23:67.1 (SBE:NBE:PBE)
13-03-2010 9:38 AM
thanks
j
13-03-2010 1:50 PM
Your sync speed may have reduced because the DLM has raised the target noise margin to reduce disconnections; have you experienced a number of drop outs? Lots of restarts while you've been trying things? Have you noticed any noise on phone calls?
More clues might be apparent if you post a full set of router stats, sync speeds, attenuations and noise margins.
13-03-2010 7:39 PM
Ive just done the BT test see results below - something fishy - according to this test im achieving 6356 when my ip profile is now 6000 kps
also included noise stats etc.
Any opinions would help - im not sure whats going on (as usual)
j
test1 comprises of Best Effort Test: -provides background information.
Download speed achieved during the test was - 6356 Kbps
For your connection, the acceptable range of speeds is 600-6000 Kbps.
Assured Rate IP profile on your line is - 6000 Kbps
Status TxPkts RxPkts Collisions Tx B/s Rx B/s Up Time
WAN PPPoA 552697 646314 0 4263 21694 07:52:21
LAN 10M/100M 596438 533602 0 19761 4564 07:53:13
WLAN 11M/54M 59268 27302 0 2403 108 07:51:55
ADSL Link Downstream Upstream
Connection Speed 7375 kbps 443 kbps
Line Attenuation 37.5 db 18.7 db
Noise Margin 9.8 db 25.5 db
15-03-2010 1:21 PM
Are you connected to the master socket? Is there any noise on the phone line?
15-03-2010 7:00 PM
does not appear to be any noise on the line
Just wondering whether restarting should have any effect
