7800n Ewan Throughput
- Re: Capped @ 66.5MB
Re: 7800n Ewan Throughput
27-12-2013 7:03 PM
IAn
Re: Capped @ 66.5MB
27-12-2013 7:50 PM
I had a predicted 50Mb rate when I signed up almost a year ago, got around 76Mb when first connected and have settled down to a pretty consistent 65Mb/s almost a year later. I'm sure if I rebooted my modem I'd get a touch more out of the line for a while but it's hardly worth it for the 4-5Mb extra speed for a few weeks.
Re: Capped @ 66.5MB
27-12-2013 8:58 PM
it went live about 14 days ago
27-12-2013 8:59 PM
27-12-2013 10:01 PM
27-12-2013 10:12 PM
The slowdown due to crosstalk is in the sync. The OP has high sync but unhappy with the throughput.
27-12-2013 10:17 PM
Is it possibly to do with the discussion in this tbb thread? Other stuff running on your LAN, or even something running on the WAN at the same time as the speed test?
I assume you are speedtesting wired to the router, not wireless.
27-12-2013 10:30 PM
I seen it bouncing off the limiter around 7.9 MB/s
27-12-2013 11:36 PM
27-12-2013 11:37 PM
28-12-2013 9:53 AM
bt ip profile shows 77/20
I need a hg612 to look at my stats
28-12-2013 11:23 AM
28-12-2013 11:31 AM
ping google.com -f -l 1474 i get a response
28-12-2013 11:39 AM
Quote from: MisterW This http://www.billion.uk.com/forum/viewtopic.php?f=9&t=345 might be useful reading...
I wonder if the most relevant link from that discussion in regard to QoS being used is crating such bottleneck slowdowns mentioned here in post 8 of 9 https://community.bt.com/t5/BT-Infinity-Speed-Connection/Infinity-installed-top-speeds-with-hub-but-...
Perhaps if Stanman can clarify whether his is using QoS or not?
28-12-2013 11:41 AM
as stated same throughput when directly connected into modem
Download speedachieved during the test was - 66.55 Mbps
For your connection, the acceptable range of speedsis 16 Mbps-77.44 Mbps .
Additional Information:
IP Profile for your line is - 77.44 Mbps
I think plusnet are capping my speed
