5mbps ...........Really plusnet ????
Portishead200
does anyone know why I pay for 25-30mbps but ive just done BT tests and its showing 5mpbs???
Please advise
19 REPLIES 19
Fixes: 387
Re: 5mbps ...........Really plusnet ????
@Portishead200 Sounds like you have a fault.
If the phone test passes, report a broadband problem via: https://www.plus.net/help/report-a-problem/broadband/
The above assumes you still have 'normal' landline connection - if you have a SOGEA (internet only) one, just use the second link to report a network issue.
@Portishead200
How did you do these tests?
Via WiFi, or a device connected by ethernet cable to the router?
The latter is far more reliable, and discounts any WiFi issues.
Portishead200
Hello sir,
Thanks for that. I have no idea if the line is clear, I got rid of my landline phone back in 1987 lol
But in all seriousness, something is up.
Portishead200
Hi Paul,  I dont even have an ethernet cable any more,  but both my phone and laptop return the same results at about 5 feet from the router,
Fixes: 387
OK, not having a phone for basic testing on an ADSL/FTTC connection is a little unfortunate - all you can do is use the second link and report a BB issue.
corringham
Seasoned Champion
Fixes: 23
Can you post the statistics from your router showing the line speed of the connection?
There are different possible causes between low speed on a fast connection, and a slow connection.
@Portishead200
OK, have you tried logging in to the router and seeing what it says about your actual and maximum connection speeds?
Assuming that you are using a Plusnet Hub2 router, using a web browser on either your phone or laptop, go to 192.168.1.254
Click on "Advanced Settings", (bottom right), then "Technical Log", (on the left). Unless you have changed it, your router admin password will be on a pull out card on the back of the router, and on the back of the router itself.
Report back with your:
Data Rate
Maximum Data Rate
Noise Margin
Portishead200
I will log into the router now and check , I have just restarted it & check the cabling from outdoors to the router and all seems normal and untouched,
Portishead200
Fixes: 387
@Portishead200 You have a fault - use the 'report a broadband fault' link in my original post.
Portishead200
thanks man
willcutforth
Fixes: 113
@Portishead200 I can see the diagnostics bot worked and it is now with Openreach. It should be fixed within 72 hours.
 Will Cutforth
willcutforth
Fixes: 113
Actually I have just checked and it is requesting an appointment. When would you be free for one, the appointments are 8-1 or 1-6?
 Will Cutforth
Portishead200
The message says they can fix with out visiting the property?Huh
But if they need to then 1-6 but they need to call me and give me 10 minutes to get here.   I cant sit around for 6 hours !!!
