230M from exchange, speed is dire
- 230M from exchange, speed is dire
28-11-2010 11:59 PM
Estimated line speed: 7.5Mbps Current line speed: 7Mbps
I was a bit disappointed given its an "up to" 20Mb product but then yesterday it's dropped to 1.5Mb. I'm literally 5 mins walk from the exchange so don't think the line can be that long, is there anything I can do?
Re: 230M from exchange, speed is dire
29-11-2010 7:36 AM
What does a BT speedtest give you?
Just because you are near the exchange does not mean that is the route your telephone wire takes. It may be much longer than you think.
29-11-2010 7:38 AM
to get your stats, the info is here http://www.kitz.co.uk/adsl/frogstats.php
29-11-2010 12:20 PM
ADSL Type Interleave Path
Status SHOWTIME
Downstream Upstream
Data rate(Kbps) 1952 64
Noise Margin 13 6
Output power(dBm) 20 10
Attenuation(dB) 122 194
From speedtest.bt.com:
Download speedachieved during the test was - 1274 Kbps
For your connection, the acceptable range of speeds is 400-2000 Kbps.
Additional Information:
Your DSL Connection Rate :1952 Kbps(DOWN-STREAM), 64 Kbps(UP-STREAM)
IP Profile for your line is - 1500 Kbps
29-11-2010 12:43 PM
Can you try the test socket with nothing else connected and report the stats again
29-11-2010 2:47 PM
I've just ran a line test and your attenuation is 20dB, which sounds about right. The problem here is your sync rate. Once you're in the test socket give me a shout so I can run another test.
Jojo
29-11-2010 3:44 PM
29-11-2010 4:39 PM
Tested at 16:35 and still syncing at 1952k. If you were still in the test socket then I'm flummoxed. You would need to revisit the fault you started to open and finish answering the questions.
Jojo
29-11-2010 4:46 PM
29-11-2010 4:55 PM
Did you note the upstream speed when connected to the test socket
29-11-2010 5:50 PM
30-11-2010 9:32 AM
I see your connected now. Are you in the test socket?
Jojo
30-11-2010 12:19 PM
30-11-2010 12:38 PM
Forgive me if you've already done this but have you changed the filter? What router are you using, and are you able to test another one?
Jojo
30-11-2010 12:42 PM
