Terrible speed please update
- Terrible speed please update
25-11-2010 1:25 PM
Ross
Re: Terrible speed please update
25-11-2010 1:52 PM
I'll take a look at this now for you.
Jojo
25-11-2010 2:00 PM
I have now replied to your ticket.
Jojo
25-11-2010 2:14 PM
25-11-2010 2:27 PM
I've just ran a line test and your BT profile is now 3000, I' have matched the PN profile and you will see the increase if you reboot your router via the disconnect/reconnect option in your router interface.
Jojo
25-11-2010 2:44 PM
25-11-2010 3:33 PM
Yes, looks like that's the reason why. The PN profile will usually follow within 24 hours.
Jojo
26-11-2010 10:49 PM
29-11-2010 9:37 AM
Your SNR at the moment is 22dB so that'll be keeping your sync rate, and consequently, your profile down. The disconnects don't look to be so many at the moment...
How is your kit set up? Are you on an extension cable/socket?
Jojo
29-11-2010 12:34 PM
29-11-2010 2:39 PM
Ok, well that's probably the reason for the high SNR. If you plug your router into the main socket, preferably the test socket I can run another line test and do a comparison (you don't need your computer plugged in, just your router) remembering to disconnect via the router interface so as not to affect the DLM. Can you let me know when you can do this so I can do the test?
Jojo
29-11-2010 5:53 PM
ADSL Link Downstream Upstream
Connection Speed 3584 kbps 448 kbps
Line Attenuation 51.0 db 26.5 db
Noise Margin 12.0 db 16.0 db
Here is a speed test from your site
Today 17:50 251 kbps (31.4kB/s) 324 kbps (40.5kB/s)
Fingers crossed that it could of been the filters if not I'll try the master socket tomorrow, for now though could you match my pn profile with my ip profile.
30-11-2010 9:45 AM
Latest line test has 2656k sync and 17dB SNR the profile on both BT & PN are 2000.
Jojo
30-11-2010 1:35 PM
I'm plugged into the test socket now like you asked so where do we go from here
30-11-2010 4:57 PM
Your sync rate is now 3616k with SNR of 12dB which would give you a profile of 3000. I could try an SNR reset if the line stays stable there and that may lift it more.
Jojo
