21CN Training Question
- Re: 21CN Training Question
- « Previous
- 1
- 2
- Next »
10-08-2009 9:54 AM
10-08-2009 10:00 AM
13-08-2009 7:15 PM
There are two lines of interest
Status: ShowtimeRetrain Reason: 0
Training Status: Showtime
This is what it has said since I joined the trial and I am now past the first 10 days training, so I was expecting the information to have changed.
Therefore is the line still training or has it never trained in the first place or am I just an idiot misinterpreting the information?
Rich
13-08-2009 11:55 PM
"Status: ShowtimeRetrain Reason: 0" means the router needed to sync and Reason 0 was the cause of this (I'm not sure what 0 signifies (had it just been powered up at sync time - some days ago - cold start?))
"Training Status: Showtime" means the router is now in its normal fully synced operational state"
David
14-08-2009 9:17 AM
14-08-2009 9:33 AM
When I had my open ticket about my line speed and stability, fault tests were run on several occasions (May-June this year). Here's a selection of data from them
Date Down sync BRAS MSR recalc? MSR FTR Comments
20/5 Not recorded 2500 N 2272 2272
22/5 3068 2500 N 2272 2272 On banded profile
27/5 4148 2250 N 2272 2272 Banding removed
1/6 N.R. 2250 N 2272 2272
5/6 3068 2250 N 2272 2272 Banded
10/6 5152 4500 N 2272 2272 Banding removed. 4500 isn't a typo!
16/6 3068 2250 N 2272 2272 Banded
So, on my line FTR is 100% of MSR. And this never gets recalculated.
Is this a bug or a feature?
Graham
14-08-2009 9:35 AM
Graham
14-08-2009 10:23 AM
test heading | test heading 2 | end
1 | 4 | 7
2 | 5 | 8
3 | 6 | 9
16-08-2009 11:59 AM
just
like
this
More substantively, do you have an explanation of why my MSR and FTR are the same?
Graham
17-08-2009 11:44 AM
The BT site that gives out those details is being non responsive for me currently, so I'll be happy to check again later on.
20-08-2009 4:32 PM
Graham
20-08-2009 4:45 PM
Bizarrely - MSR & FTR *were* 2272
However, MSR is now (as of the 17th) 2848Kbps with an FTR of 2278Kbps.
20-08-2009 4:49 PM
Quote from: orbrey @grahamt you can use code tags to use a fixed width font so tables like that will look as you want - it's the button with the hash symbol on it on the compose message screen.
1 | 4 | 7
2 | 5 | 8
3 | 6 | 9
Or he could use pre tags (the button immediately to the right of ) if he doesn't want it in a box:
1 | 4 | 7
2 | 5 | 8
3 | 6 | 9
20-08-2009 5:11 PM
And thanks to jelv for the extra formatting tip.
Graham
22-08-2009 9:46 AM
I was hoping that if I turned the line off before it became unusable I could switch on again this morning and still have an unbanded speed. No such luck. Back to the old 3069-777-14dB routine. I guess that there were just too many errors on the line when the higher frequencies were being used.
Graham
- « Previous
- 1
- 2
- Next »
