*21CN ONLY* Do you think your PN profile is not updating as it should?
- *21CN ONLY* Do you think your PN profile is not up...
Re: *21CN ONLY* Do you think your PN profile is not updating as it should?
30-06-2013 3:36 AM
From BTW:
Quote IP Profile for your line is - 30.66 Mbps
From PN:
Quote Estimated line speed:
39Mb (Accurate to within +/- 1Mbit) - Checked on 2013-06-26 03:11:44
Current line speed:
37 Mb
30-06-2013 9:18 PM
7.15 is a ridiculous value for 2 reasons: first, my line is never going to be anywhere near that fast, and second, 7.15 looks like the highest possible profile for a 20CN connection, but I'm on 21CN.
30-06-2013 9:48 PM
I wonder if it was the same time as my 20CN one also went to the same value.
01-07-2013 10:12 AM
Current line speed:
74.4 Mb
Yet conducting a BTW performance test shows:
Download speedachieved during the test was - 39.73 Mbps
For your connection, the acceptable range of speedsis 16 Mbps-42.14 Mbps .
Additional Information:
IP Profile for your line is - 42.14 Mbps
Suspect the above issue could upset throttling?
01-07-2013 10:16 AM
01-07-2013 4:47 PM
Are Delta reports coming through from BT?
01-07-2013 5:09 PM
I don't know how they can monitor and push back to BT if delta reports don't arrive when there are still problems with their own system.
02-07-2013 7:36 AM
I guess the new 21CN system is quicker than losing things in the post, somebody discovered it would be faster to fax the profile changes over to plusnet instead! But I guess the person writing out the profile changes at my exchange must have hard to read handwriting!
02-07-2013 10:24 PM
[Edit] And 30 minutes later it resyncs again (almost matching the PN Profile - I suppose that's one way to correct it!).
29-07-2013 7:47 AM
Quote from: chrispurvey Delta reports we're not being generated every time that a re-sync event took place, this meant that no information was generated to us to update your speed profile if the sync rate had changed.
The way the information is generated to the delta reports has been adjusted, although currently any changes under 256kbps will not be reported to us as it stands, this is just to manage volume while we see if there is any initial difference.
0:05
3:05
6:05
17:05
20:05
This is then followed by the us running a script an hour later with the download date to our systems to update your profile:
1:05
4:05
7:05
18:05
21:05
We're also refining our scripts slightly this week, this is due to a few errors that have been encountered when applying the updates to our systems.
We're currently monitoring this.
Are the script times given here still correct or have they been modified?
Should this information not be on the help pages somewhere?
21-08-2013 3:29 PM
38 on btw, 33 on plusnet
21-08-2013 7:59 PM
Once synchronised it's at a BT profile value of 6.9 but yet the PN profile still gets auto updated with this 3.3 far too low number. As a result I'm left with a stupidly low download speed for a few days before the profile finally gets corrected with the right value.
I don't know what's going wrong but someone should be looking into this as it's rather annoying and totally puzzling, if only infrequent as our line is pretty stable most of the time. This certainly is not the way the profiling system is suppose to work.
22-08-2013 11:54 AM
Quote from: udk please update my profile
Your profile is now set correctly.
@RPMozley
Not sure why we received a delta report for your line, I'll feed this back to BTW.
Your sync rate has not changed as you can see below.
This was the report that came through from BTW on the 21st.
As you can see, 3 and a bit hours later your profile has then been updated, I've now corrected your profile.
Quote from: jelv
0:05
3:05
6:05
17:05
20:05
1:05
4:05
7:05
18:05
21:05
The times haven't changed, I'm working with our development team to see if we can get this run more frequently and also digging into the missed profile updates.
18-09-2013 8:52 PM
Two possible theories as to why the problem of transferring a number from one system to another cannot be solved:
a) Plusnet are not capable of fixing it
b) Plusnet don't want to fix it
18-09-2013 9:03 PM
