21CN-Exchange-Availability checker
FIXED- Subscribe to RSS Feed
- Re: 21CN-Exchange-Availability checker
- « Previous
- 1
- 2
- Next »
03-05-2016 5:47 PM
Here we go; same results. Must state that this is wifi as my Dell has no Network socket.
I could dig out an old Vista pc, with Network port.
03-05-2016 5:49 PM
I'm just trying a session kill from our side, try a speedtest again in a few minutes and see how that looks.
on
03-05-2016
6:12 PM
- last edited on
03-05-2016
6:14 PM
by
Mav
Attach- no change.
Here are router stats too: did you want me to refresh connection via Hub s/ware
| Product name: | Plusnet Hub |
| 2. Serial number: | [Removed] |
| 3. Firmware version: | Software version 4.7.5.1.83.8.217.1.1 Last updated 13/02/16 |
| 4. Board version: | Plusnet Hub One |
| 5. DSL uptime: | 1 days, 14:39:11 |
| 6. Data rate: | 917 / 3395 |
| 7. Maximum data rate: | 917 / 3608 |
| 8. Noise margin: | 6.0 / 4.4 |
| 9. Line attenuation: | 36.2 / 61.3 |
| 10. Signal attenuation: | 35.8 / 56.4 |
| 11. Data sent/received: | 1.6 MB / 1.0 MB |
Moderator's note by Mike (Mav): Router serial number removed from a public forum
03-05-2016 7:09 PM
If you could try a disconnect/reconnect please. That'll just rule that out.
03-05-2016 7:18 PM - edited 03-05-2016 7:38 PM
Did that Chris and BT speed for uploads got worse ![]()
No luck getting my Vista PC to connect to internet via network lead.
PN hub sees it but as disconnected.
03-05-2016 7:37 PM
I'm afraid it's likely to need looking at as a fault then https://faults.plus.net
04-05-2016 11:52 AM
OK.
Hope to do some tests on master socket later, but as it's in loft have to get some extension leads ready.
Have had no luck on getting my old Vista laptop to connect to HubOne via the Ethernet port unfortunately (for speed test) ; have posted separately on that in routers thread.
- « Previous
- 1
- 2
- Next »
-provides background information.
