10 day line shaping
- Re: 10 day line shaping
10 day line shaping
06-12-2013 10:53 PM
Back to plusnet last week... not sure if I made the right decision, lets hope so.
Just curious what the "usual" plan is for the first ten days of service... I'm on day four and havent noticed any change in my router sync speed, despite rebooting it this morning as suggested.
Its only that my speedtest results are pretty naff (which I do expect on first few days etc), but with o2 my router was syncing at around 18000d/l & 1700u/l, so I am presuming that my line should be able to handle more than the current 8128d/l, 448u/l sync speed.
This was a normal ish speedtest with o2:
http://www.speedtest.net/my-result/3084036279
Currently with plusnet its
http://www.speedtest.net/my-result/3149191602
07-12-2013 10:06 AM
For a bit more help please post the stats from your router - noise margin, speed and attenuation
07-12-2013 10:54 AM
07-12-2013 11:15 AM
Line Attenuation 20.0 db 11.5 db
Noise Margin 8.0 db 24.0 db
Not sure where modulation type is, its a netgear dgn2200
Like I say, not fussed at the moment as its still early days, but was just curious if the sync speed has even tried to be increased.
07-12-2013 11:26 AM
If you put your details in here http://usertools.plus.net/exchanges/ what does it say about WBC on 21CN
07-12-2013 11:29 AM
DSL Type: ITU-T G.992.5
It is the 992.x bit which is important - possibly a red herring, but given your previous high speeds and the current figures, I'm wondering if you are not on adsl2... The modulation type will confirm or deny that.
07-12-2013 4:44 PM
Quote from: Oldjim That answers the question - you are either on 20CN or 21CN ADSL1
20CN VP capacity at this exchange is currently showing as Green.
Click here for further details
BT have not advised a planned date for WBC on 21CN
07-12-2013 4:52 PM
07-12-2013 5:09 PM
Quote from: Townman Modulation type informs us of the type of ADSL service you are running. From a TG582n (as supplied by PN) it looks like this... DSL Type: ITU-T G.992.5
Can't find that on my router. In the ADSL settings, under DSL Mode, its currently set to 'auto'. The drop down box has ADSL, ADSL2, ADSL2+. However, if I change that to ADSL2 or ADSL2+ it won't connect.
07-12-2013 6:00 PM
Sadly your findings in post 6 - as explained in post 7 - confirms what I feared, you are on ADSL 1 which is up to 8Mbs.
BT do not provide a 21CN service on your exchange - this is as fast as PN (or any other ISP using BTw offerings) can go.
07-12-2013 6:01 PM
Quote from: BlueMeany BT have not advised a planned date for WBC on 21CN
That would suggest that your exchange can only provide you with up-to 7.15Mbps on a BT phone line (with any ISP using the BT connection).
Your alternative is to see what other LLU (i.e. non-BT connection) ISPs are available on your exchange.
Try putting your details into SamKnows : Exchange Search, then click on your exchange name,
to see which providers your exchange is served by in the "LLU operator presence" section.
07-12-2013 10:26 PM
Can't see fibre coming here anytime soon, bit out in the sticks.
08-12-2013 8:51 PM
I can't even watch itv player on my smart tv with plusnet, it just keeps buffering and stalling
I've just got to work out whether I now allow my current phone provider (newcalltelecom) to transfer over to plusnet before requesting a migration to sky or such LLU provider. Sky were a bit puzzled about my phoneline, but if I allow it to transfer on 16th then they will handle everything from their end (although the advisor was trying to get me to sign up for a new line!)
08-12-2013 9:23 PM
Quote from: BlueMeany I can't even watch itv player on my smart tv with plusnet, it just keeps buffering and stalling
You must have something else going wrong ?
My connection is VERY similar to those ADSL stats you posted above, my connection currently gives about 6.7Mbps usable bandwidth, but most evenings we have iPlayer (PC) + Netflix (TV) + online gaming (Xbox Live) all running at the same time, and rarely (if ever) run out of bandwidth, and even our VoIP phones still work under that bandwidth load.
You should be speed testing at higher than 6Mbps with your 8.128Mbps sync.
Perhaps one of the Digital Care Team could take a look at your connection tomorrow.
At least you have the option to switch back to an LLU provider, I'm stuck on 20CN ADSL indefinitely, as BT are the only line provider and the local BDUK project isn't going to provide any upgrade to the local exchange.
08-12-2013 9:26 PM
'Spose I've got to wait until the 16th anyway... so will see what happens before then and take it from there.
