1 month of usless BB
- Re: 1 month of usless BB
29-11-2008 1:29 PM
Test1 comprises of Best Effort Test: -provides background information.
Your DSL connection rate: 8128 kbps(DOWN-STREAM), 448 kbps(UP-STREAM)
IP profile for your line is - 2000 kbps
Actual IP throughput achieved during the test was - 1384 kbps
nice - NOT
29-11-2008 1:51 PM
The phone call response you mentioned is extremely poor and I cannot believe you got that from Plusnet's CSC staff. My guess it was an engineer fixing your line at the exchange, not that that makes it satisfactory. Please put this aside for now, my interprestation of your BT test results is that the long running saga you've had is coming to an end.
David
29-11-2008 2:12 PM
29-11-2008 7:21 PM
I hope this is now sorted for you.
With regards the response from the CSC agent, that is totally unacceptable and you have my promise that I'll follow this up on Monday morning.
01-12-2008 1:17 AM
Your DSL connection rate: 8096 kbps(DOWN-STREAM), 448 kbps(UP-STREAM)
IP profile for your line is - 7000 kbps
Actual IP throughput achieved during the test was - 734 kbps
at 1:10am 1st 12th 2008
Data rate (Kbps)
8096 448
Secondary DNS Server 212.159.6.10
Noise margin (dB)
11.7 25.0
Output power (dBm)
19.8 12.2
Attenuation (dB)
35.0 21.0
oopsie kinda slow after starting today at a nice 6+megs download speed. slowly deteriorated from around mid afternoon . 30th 11 2008
01-12-2008 1:29 AM
My current result is
01-12-2008 1:45 AM
just used the site you asked me too , and this is teh result
just doing a fewtracert also , Microsoft Windows [Version 6.0.6001]
Copyright (c) 2006 Microsoft Corporation. All rights reserved.
C:\Users\reaper>tracert www.google.co.uk
Tracing route to www.l.google.com [216.239.59.104]
over a maximum of 30 hops:
1 1 ms <1 ms 1 ms
2 46 ms 47 ms 50 ms lo0-homesurf.ptn-ag2.plus.net [195.166.128.54]
3 49 ms 53 ms 50 ms ge1-0-0-205.ptn-gw01.plus.net [84.92.3.97]
4 48 ms 49 ms 48 ms te2-2.thn-gw1.plus.net [212.159.1.54]
5 47 ms 48 ms 46 ms 195.66.226.125
6 47 ms 46 ms 49 ms 209.85.255.175
7 64 ms 62 ms 63 ms 209.85.250.216
8 59 ms 61 ms 59 ms 66.249.95.169
9 62 ms 65 ms 65 ms 216.239.49.114
10 67 ms 63 ms 64 ms 216.239.59.104
Trace complete.
Tracing route to portal.f9.net.uk [212.159.8.4]
1 1 ms 1 ms 1 ms
2 55 ms 55 ms 50 ms lo0-homesurf.ptn-ag2.plus.net [195.166.128.54]
3 51 ms 52 ms 48 ms ge1-0-0-205.ptn-gw01.plus.net [84.92.3.97]
4 53 ms 48 ms 51 ms gi0-2-32.ptc-gw1.plus.net [195.166.129.10]
5 54 ms 62 ms 57 ms pos1-0.pih-cr1.plus.net [195.166.129.250]
6 55 ms 54 ms 54 ms vlan7.pih-gw3.plus.net [212.159.0.26]
7 57 ms 102 ms 87 ms if25.pih-lb04.plus.net [212.159.0.18]
8 59 ms 58 ms 57 ms homepages.supersurf.net [212.159.8.4]
Trace complete.
01-12-2008 1:56 AM
01-12-2008 8:26 AM
then again i have never seen below red in nearly 8 years .
speeds now ,Download Speed: 6673 kbps (834.1 KB/sec ) Upload Speed: 359 kbps (44.9 KB/sec )
01-12-2008 9:00 AM
Download Speed: 2876 kbps (359.5 KB/sec ) Upload Speed: 353 kbps (44.1 KB/sec )
01-12-2008 9:06 AM
I'm glad to see that you're back on the BT Network.
What sort of speeds are the BT Speedtester giving you at "normal" times of the day?
01-12-2008 10:10 AM
01-12-2008 10:40 AM
There's absolutely nothing wrong with your sync speeds. In fact they're actually really good.
The problem you're suffering from is poor throughput, which appears to be exchange related. Hopefully BT will add some further VP capacity to your exchange before long, which should result in an improvement to your speed
01-12-2008 10:47 AM
hrm improve our exchange, its the main one in teh city centre. improve yes, degrade more like lol, they will of course be making sure the international lines for bussines get priority. its is also earmarked for upgrade ending January next year, which from past history will more like be January 2010. ah well the joys of modern living.
oh and my iwfes line runs through teh same exchange, she has a stable 4 meg line and the most degredation i ve seen is a drop from 4 to 3,96 , so erm .. i think someone dosnt like me .
01-12-2008 10:59 AM
I'm trying to remember, did you say it was BT or Sky?
