what is fibre optic???
- Re: what is fibre optic???
03-06-2012 6:40 PM
ok ,, was with BT NOW PN ( CHANGED LAST WEEK)
have a usage of 10gb per month,,, the service is really fast ,,
in fact cant complain...
just wondering why i would need fibre optic... or do i have it now. ( £6.49pm )
Message 1 of 8
(3,562 Views)
7 REPLIES 7
03-06-2012 6:58 PM
No you haven't.
http://www.plus.net/fibre-broadband/
http://en.wikipedia.org/wiki/Optical_fiber
http://en.wikipedia.org/wiki/Fiber-optic_communication
http://www.uswitch.com/broadband/compare/fibre_optic/?gclid=CPWCtcTQsrACFdKBfAodqSikVw#products=more...
Plenty more out there, Google is your friend as they say
Message 2 of 8
(2,807 Views)
03-06-2012 7:15 PM
many thanks.... having read it ,, would i suggest its really for high users only , i mean 40gbs is very high?
i didnt need a engineer when my basic router arrived last week ( 10gbs)
Message 3 of 8
(2,807 Views)
03-06-2012 8:08 PM
Well you need to be careful if you start streaming video. Some HD stuff you could easily use nearly 2Gb per hour and possibly upto 3Gb.
Best quality SD could be upto 1Gb per hour.
Message 4 of 8
(2,807 Views)
03-06-2012 8:32 PM
Quote from: kdoug007 i didnt need a engineer when my basic router arrived last week ( 10gbs)
For fibre, an engineer is needed to install a special faceplate for the fibre service and connect you onto the fibre DSLAM.
Message 5 of 8
(2,807 Views)
03-06-2012 8:44 PM
It's debatable whether anyone who can get a decent broadband speed in the first place needs fibre optic speeds. Even the BT ad. can't find a better justification for fibre than the ability to download Duran Duran albums very quickly. A household with multiple teenagers/young adults (as per the ads) might justify fibre if they all want to stream videos simultaneously. But in that scenario a huge amount of data could be downloaded, easily 10 GB every few days, so you don't want to be with a company like Plusnet that imposes strict limits. By the way, kdoug007, you do understand the distinction between speed and capacity, don't you? Plusnet Value Broadband imposes a monthly capacity limit of 10 GigaBytes. If your download speed is 10 Megabits per second you would use your full monthly capacity after 8000 seconds (i.e. 2 hours 13 minutes) of downloading at full speed.
Of course, there are people with very slow broadband who would derive a lot of benefit from fibre speeds but don't necessarily want to consume huge amounts of capacity. But by and large BT don't want to supply such consumers so they don't get the option of fibre.
Message 6 of 8
(2,807 Views)
04-06-2012 10:06 AM
interesting post,, thnks...
i was fine with bt usuage and also pn.. so far in 2 weeks have used 2gb.30
Message 7 of 8
(2,807 Views)
04-06-2012 1:49 PM
Quote from: ReedRichards It's debatable whether anyone who can get a decent broadband speed in the first place needs fibre optic speeds.
I'm sure similar things were said when ADSL first came out. Going from the fastest dialup speeds of 56kbps to 1mbps was a massive jump, which at the time seemed complete overkill.
However, as has been shown multiple times in the computer industry, usage expands to consume the available resources.
Personally, I don't do a lot of downloading, but when I do, I want it as soon as possible. e.g. Getting OpenSUSE in 10 minutes rather than 2.5 hours.
Message 8 of 8
(2,807 Views)
