turn on suggestions
Thomson 585v8 log files
- Thomson 585v8 log files
04-06-2012 6:14 PM
Anyone know how to access the router log files remotely?
Eg can you Telnet in and get log files, or even set things up so that logfiles can be accessed from the network. This seems to be commonly available with other routers.
1 REPLY
Re: Thomson 585v8 log files
04-06-2012 7:02 PM
Yes, telnet access to the TG585v8 is available using the normal port and the same username and password as for browser access. Once logged in typing help at the prompt will display the commands available.
The systemlog show command will display a longer version of the log then that shown via the web interface.
David
