slow broband and Noise on phone line
khan5
hi plusnet support team my have issue with my phone line and slow broadband agin it happen before first week of plusnet boradband start and now again can u please check the phone line and slow broadband .thanks
14 REPLIES 14
adamwalker
Fixes: 221
Re: slow broband and Noise on phone line
Sorry to see you've been having problems.
I've tested the line and no issues are being flagged up.
Can you please make sure the checks here have been followed https://www.plus.net/help/phone/phone-line-troubleshooting/ do let us know how you get on.
 Adam Walker
khan5
Hi can u please check it again because my broadband not work all day still orange and red light flashin and phone line ded no tone in phone set
Tags (1)
adamwalker
Fixes: 221
OK, tests are indicating a fault with the line.
Please report that with us here so we get all the information we need from you to investigate it further: https://www.plus.net/my-account/tools/phone-troubleshooter/
Drop us a reply back here when you have and I'll make sure that gets picked up.
 Adam Walker
khan5
Hi it says call to customers service nothing else. Can u please fix my phone line. Thanks
khan5
Hi all the information right and can plus net support team fix it thanks
adamwalker
Fixes: 221
Can you report it using the link provided please?
Send me a reply here when you have.
 Adam Walker
khan5
I have click on link and when I click on check my line it comes up call to this number 0800 I am using my mobile at moment
Chris
Legend
Fixes: 169
I've tested your line and it's showing a potential issue with your internal equipment. I've created a support ticket on your account that has the next steps and what testing we'd need. You can view that here and if you reply with the information required we'll get that progressed.
khan5
hi i have folow the vedio and fond my hub 5 gone fualty when i unplug router phone tone come up when i plug router in phone tone gone .can u please replace fualty hub 5 please.thanks
adamwalker
Fixes: 221
Given what you've mentioned and the results we were seeing on a line test yesterday I don't think the router is faulty, it sounds more likely that the equipment might be connected to the line incorrectly.
Is the socket the router connects to an Openreach branded one with two sockets such as the one shown here?
 Adam Walker
khan5
hi plusnet support team can u please check why noise margin very low on my line and can u put up to 9db .thanks
Chris
Legend
Fixes: 169
Is the noise margin being low causing you any issues? We're happy to request an increase to 9db, but this will lose you some speed.
khan5
hi yes becauseyester day it went down to 1.5 db and i have slow broadband and disconaction put 9db for week or 2 and will see how it going.
Chris
Legend
Fixes: 169
That's been put through for you. It should take effect within the next few hours.
