sagecom router wont connect access denied
- sagecom router wont connect access denied
02-08-2013 1:00 PM
i decided to try and connect a different router because of frequent drops in connection but when i put in the login details for the intenet i get access denied.
it says this
PPP Username and Password (Interface: pppoa0, Description: pppoa_0_0_38 )
PPP usually requires that you have a user name and password to establish your connection. In the boxes below, enter the user name and password that your ISP has provided to you.
i tried myusername@plusdsl.net and my password and i also just tried my username alone
im definitely not using my forum username and the password is correct
it says this
Message 1 of 7
(4,013 Views)
6 REPLIES 6
Re: sagecom router wont connect access denied
03-08-2013 5:15 PM
anyone?
still cant get logged in access denied every time it tries to connect. it can see theres a connection there because it shows upstream and downstream it just wont connect
Message 2 of 7
(2,410 Views)
04-08-2013 1:30 AM
Is the router locked to a particular ISP, even though the presence of those boxes suggests otherwise?
David
Message 3 of 7
(2,410 Views)
04-08-2013 2:21 AM
Quote from: totalguy it can see theres a connection there because it shows upstream and downstream it just wont connect
Certainly suggests that ADSL is syncing OK
Quote from: totalguy PPP Username and Password (Interface: pppoa0, Description: pppoa_0_0_38 )
Looks OK: http://www.plus.net/support/broadband/hardware/broadband-connection-settings.shtml
Quote from: totalguy i tried myusername@plusdsl.net and my password ...also just tried my username alone ...im definitely not using my forum username and the password is correct
You DO need the password, are you 100% sure it's correct (same as Member Centre login password)?
Where did the Sagecom come from? spraxyt's reply may be the explanation.
Call me 'w23'
Message 4 of 7
(2,410 Views)
04-08-2013 11:14 AM
the password is 100% correct
it was a sky router but i flashed it with new firmware giving me access to username and password and several other usually hidden settings.
Message 5 of 7
(2,410 Views)
04-08-2013 11:37 AM
A quick Google search suggests that the 'unlocked' firmware for the sagem f@st 2504n may still leave the device locked to Sky.
http://forum.kitz.co.uk/index.php/topic,11994.msg227921.html?PHPSESSID=b84cec1bfb166f3c594ae92d10dbc...
Call me 'w23'
Message 6 of 7
(2,410 Views)
05-08-2013 3:58 PM
ah great what a waste of time!!!
now i need to buy a new router
jim:quote
jim:quote
Message 7 of 7
(2,410 Views)
