connection dropping
totalguy
connection dropping
my connection dropped yesterday not sure how many times as i wasnt on it and it dropped today. unusual for this to happen i dont usually see any and my computer doesnt tell me when its dropped since i have had plusnet
Fixes: 62
Re: connection dropping
have a look at the router log - if it is a Plusnet router it is here http://192.168.1.254/cgi/b/events/?be=0&l0=1&l1=2
totalguy
Quote from: Oldjim
cant see much there loads of firewall checks i saw a drop and reconnect today but i cant see much else it only shows today
edit: JUST DROPPED AGAIN
Aug 2 11:40:53 PPP link down (Internet) [84.93.101.49]
Info Aug 2 11:40:51 xDSL linestate down
Info Aug 2 11:40:20 xDSL linestate down
totalguy
2 more 11:45 & 11:56AM
wired connection too
Fixes: 65
Here's a view of the disconnections over the past 24 hours or so:
<img src="http://community.plus.net/visualradius/generated/image13754409475398.png"/>
Don't worry about posting each time you get disconnected. You just need to raise a <a href="http://faults.plus.net/">fault</a> and we'll help you get that sorted Smiley
Adam
 Adam Walker
totalguy
found the problem. when i put my nas drive on for downloading to it, the connection drops when its not on it seems fine no drops.
it shouldnt do this though never had this problem before.
totalguy
Quote from: _Adam_Walker_
Adam
any chance of another one of those that includes from about noon until now?
and any idea's why my nas drive is affecting the router? it never used to,  only used my nas drive in the past few days since i got this new plusnet router a few weeks ago.
totalguy
it seems my nas drive is probably not the problem now as ive had it on for hours and no drops.
connection seems better today although theres always room for improvement
totalguy
well it seems to have sorted itself out so i will never know what it was, very annoying all the same
now just to buy a new router when i can afford it
