raspberrypi.org not accessible on PlusNet?
IcyBee
Can anyone else access raspberrypi.org?
Everything else on the internet is fine for me, but I can't get to the one site I need this evening.
It can be reached on my (non-PlusNet) phone and http://www.isitdownrightnow.com/raspberrypi.org.html says that the site is up and reachable.
9 REPLIES 9
pjmarsh
Fixes: 20
Re: raspberrypi.org not accessible on PlusNet?
It's up and running for me.
IcyBee
Thanks for trying.
It's weird, but every device connected to my router cannot see that site.  All other sites are fine.
Does anyone know why one particular site would stop working on a broadband connection?  Has my IP been banned or something?
If I turn off wi-fi and connect my phone to my EE 4G connection, it's fine.  But I want to download updates on my ethernet only  Raspberry Pi (v1).
IcyBee
Oh.  Just restarted my router and it's working now.
Weird.
ejs
Aspiring Hero
Fixes: 25
Plusnet's DNS servers seem to have some issue with it:
$ dig @212.159.6.9 raspberrypi.org
; <<>> DiG 9.11.3-RedHat-9.11.3-6.fc28 <<>> @212.159.6.9 raspberrypi.org
; (1 server found)
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: SERVFAIL, id: 52887
;; flags: qr rd ra; QUERY: 1, ANSWER: 0, AUTHORITY: 0, ADDITIONAL: 0
;; QUESTION SECTION:
;raspberrypi.org.		IN	A
;; Query time: 485 msec
;; SERVER: 212.159.6.9#53(212.159.6.9)
;; WHEN: Tue Jun 26 18:47:46 BST 2018
;; MSG SIZE  rcvd: 33
Other DNS servers seem OK with it:
$ dig @8.8.4.4 raspberrypi.org
; <<>> DiG 9.11.3-RedHat-9.11.3-6.fc28 <<>> @8.8.4.4 raspberrypi.org
; (1 server found)
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 16148
;; flags: qr rd ra; QUERY: 1, ANSWER: 2, AUTHORITY: 0, ADDITIONAL: 0
;; ANSWER SECTION:
raspberrypi.org.	43	IN	A	93.93.130.214
raspberrypi.org.	43	IN	A	93.93.128.230
;; Query time: 28 msec
;; SERVER: 8.8.4.4#53(8.8.4.4)
;; WHEN: Tue Jun 26 18:49:13 BST 2018
;; MSG SIZE  rcvd: 65
IcyBee
Yup - it's not accessible any more.  Thanks PlusNet!
Rebooting the rooter didn't help this time - it must have been a coincidence.
I suppose I'll try a different DNS server then.
IcyBee
I've switched to OpenDNS, and it works now.
Looks like PlusNet's DNS servers are at fault.  First time I've ever experienced this.
bobpullen
Fixes: 316
Definitely something that needs a bit of digging (no pun intended). Will see if I can get somebody to take a look...
Edit: raised under ref: 573335.
bobpullen
Fixes: 316
We kicked the DNS caches yesterday so I'm hoping this is resolved now? Seems to be from where I'm sat:
~ $ dig raspberrypi.org @212.159.6.10
; <<>> DiG 9.9.5-9+deb8u13-Raspbian <<>> raspberrypi.org @212.159.6.10
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 10911
;; flags: qr rd ra; QUERY: 1, ANSWER: 2, AUTHORITY: 0, ADDITIONAL: 1
;; OPT PSEUDOSECTION:
; EDNS: version: 0, flags:; udp: 4096
;; ANSWER SECTION:
raspberrypi.org.        283     IN      A       93.93.128.230
raspberrypi.org.        283     IN      A       93.93.130.214
;; Query time: 12 msec
;; SERVER: 212.159.6.10#53(212.159.6.10)
;; WHEN: Thu Jun 28 10:16:30 BST 2018
;; MSG SIZE  rcvd: 76
IcyBee
Yes - it seems to be working now (I have switched back to the PlusNet DNS servers).
Thanks for sorting it out!
