new router advice required
- new router advice required
- « Previous
- 1
- 2
- Next »
Re: new router advice required
29-08-2008 11:06 PM
link http://forums.whirlpool.net.au/forum-replies-archive.cfm/757087.html
My boss has a speedtouch 585 and is nas device is used as abackup device so the kids dont crash his whole business when losing files
But pierre_pierre again says the routers not fast enough but do download speeds on the box work in real life. i.e gov test shows my new car does 59mpg but I only get 51mpg
puddy
29-08-2008 11:10 PM
just a gentle reminder here to remain on topic and that personal insults and trolling won't be accepted around these parts.. play nicely or I'll be forced to get my stick out. :mand:
30-08-2008 1:08 AM
Quote from: pierre_pierre not much use to the OP then he wants 58M
I was quite surprised to get a peak of 3MBytes/sec over wireless - that's probably about 30Mbits/sec
Obviously there's overhead with a slow disk drive (only 7200 rpm) plus protocol overhead.
I suspect a windows (SAMBA) version would be even slower.
I was using nfs.
30-08-2008 6:47 PM
30-08-2008 11:31 PM
01-09-2008 6:36 AM
Quote from: pierre_pierre the requestor want 58M wired NAS, as per Roger Loxtons post can we get on topic
You stated a speedtouch was only 58mbps which was a min requirement by op so the router needed to be faster. So I said their are faster routers but the speeds on the box are max speeds under the best conditions what router gives 99% of the advertsied speed? To make it easy for you to understand I said my mpg for my car GOV state 59mpg but I only get 51mpg.
Lets try an other way for you plusnet advertise speed up to 8mg for download so who get 8mg?
Get the point?
Puddy
ps we all read what Roger put we DONT need you to repeat it!!!
01-09-2008 7:36 AM
A a wired NAS capability
B any clue to its lan speed
My comments have all been that it does not meet the requesters requirement
Now read Roger Loxtons comments
01-09-2008 7:59 AM
It states it supports 802.11g, which is the standard for a 54Mbps WiFi connection, it also states that it has 4x10/100 Ethernet ports, which are stated by the OP as a necessity to connect his NAS via a wired connection.
I'm at a loss as to why you would link to a review showing that the recommended router meets the requirements, and then complain that it doesn't.
What exactly is your point? - Have I missed something obvious?
01-09-2008 8:15 AM
Quote 54mb and above
wired network connections for NAS
if that is the same as what you say OK, but neither I nor Puddy stated that
01-09-2008 8:48 AM
"wired network connection for NAS" is very unlikely to be referring to a token ring ethernet since they are so rarely used these days that I've never seen a router incorporating connections of this type (ie - coaxial networking) - so it stands to reason that the only likely requirement inferred is for a 10/100 ethernet connection. (Possibility of GB networking being a requirement I suppose, or even fibre networking, however these are more specialised - thus if they were what was required, the OP would have probably had advanced knowledge, and would have known to include them specifically in the SoR.)
As you say, its a bit of guesswork to come up with those answers, but there isn't a logical alternative for either, and certainly not another one that is more likely, thus stating that the suggested solution is not compatible with the SoR is disingenuous to say the least. (Again - IMO)
Perhaps it would have been better to ask for further clarity in the SoR if you felt confused about what was really required, rather than telling people that the suggested solution was not compatible with the SoR.
01-09-2008 8:53 AM
- « Previous
- 1
- 2
- Next »
