Dial-up number
Tigger
Dial-up number
Bit confused - I might have to do without our wireless router for 24 hours, what dial up number can I use in its place? We're on a Small Business Premier tarriff.
Unfortunately, the Help page didn't actually mention a Small Business Premier account, so I'm unsure what to do.
Sorry to be so thick!
1 REPLY
Fixes: 5
Re: Dial-up number
Does the Connection Details page give you a dial up number?  Mine (PAYG account) says 0845 1400101.  Do not try to connect to this at the same time as you are connected to Broadband with the same username, and you will be assigned the same IP address, and you will experience problems on both connections.
Phil
