Which Router ?
- Which Router ?
Which Router ?
13-04-2011 8:42 PM
Which adsl/adsl2+ wireless router can have all information such as the line ip profile rate because I think it better from the router instead of using bt speedtester not working anymore (cannot find out what is the ip profile rate is on the line ?)
Message 1 of 7
(921 Views)
6 REPLIES 6
Re: Which Router ?
13-04-2011 8:45 PM
None of them will give that information
Message 2 of 7
(446 Views)
Re: Which Router ?
13-04-2011 8:47 PM
I think all manufacturing should working on this for future wireless router to detect the true ip profile line speed from the local exchange to the modem. I cannot see why not ? Fed up of BT kept us in the dark not knowing what is the profile rate is even when bt speedtester not working at all.
Message 3 of 7
(446 Views)
Re: Which Router ?
13-04-2011 9:00 PM
The reason why not is that the information isn't or perhaps cannot be made available from the equipment in the exchange.
The only other solution is to use the value here which should mirror it https://portal.plus.net/my.html?action=data_transfer_speed
Message 4 of 7
(446 Views)
Re: Which Router ?
13-04-2011 9:04 PM
Yes but these https://portal.plus.net/my.html?action=data_transfer_speed
doesn't always catch up on bt end of correct ip profile rate, not always up to dated.
Message 5 of 7
(446 Views)
Re: Which Router ?
15-04-2011 3:48 PM
I cannot see any reason why BT cannot do not will not provide a customer info page just giving the line profile (may need to be subject to some security checks). Many users run the speedtester just to find out their profile, if the info were available separately then the tester would probably not be so congested.
Call me 'w23'
Message 6 of 7
(446 Views)
Re: Which Router ?
15-04-2011 3:52 PM
I do agree with you. It really annoying that BT won't pass on the customer. To run spedtester to find out line ip profile is rather annoying and cause the speedtester overload and congested by milion of peoples using bt speedtester every hours to check their ip profile rate.
jim:quote
jim:quote
Message 7 of 7
(446 Views)
