VPN / router / broadband issue
- VPN / router / broadband issue
14-07-2014 10:31 AM
To work from home I use vmware view with a vpn to access a virtual desktop. Since moving to plusnet the vmware fails to establish a secure connection especially between 8 and 10 am. It usually connects eventually and then is fine for the rest of the day however odd days it hasn't worked at all all day or has worked almost straight away. I have tested it with a mobile broadband provider and it works fine. My work IT dept have checked the laptop, the software, the server etc. and all that is fine.
I have tried resetting the router, switching off the router firewall, opening various ports (the fact that it works some of the time seems to suggest none of this is necessary though) with no change. I haven't been able to check with a different router as I don't have another one to test it with. Plusnet line checks report no speed or connection issues.
The broadband works with everything else, but I need to be able to work from home without this hassle. I have had a request with plusnet support since 24th June with little success.
Anyone have any clue why I would have these problems? And if there is anything I can do to fix it?
Thanks for any help offered.
Paul
Re: VPN / router / broadband issue
14-07-2014 12:26 PM
There's a similar thread here.
It links to http://npr.me.uk/vpnissue.html which may be worth a try.
14-07-2014 1:23 PM
I'm struggling to understand why it would work some of the time if it's a problem like this.
But I guess anything worth trying! I've just had a go at the suggestion in that thread and it hasn't worked. I found another thread about using a VPN so will try that too.........this one: http://community.plus.net/forum/index.php/topic,102798.0.html
Paul
14-07-2014 1:54 PM
Paul
14-07-2014 2:13 PM
You could try changing the DNS settings in the router to see if that makes any difference http://npr.me.uk/telnet.html#dnsr10
OR maybe even change the DNS server settings on the laptop if you can.
16-07-2014 10:01 AM
Have tried to follow the steps to change the DNS settings on the router - I was trying to follow the note about the "intf" bit but the command "dns server forward dnsset list" just showed me an empty table. Sorry, this is all a bit beyond my understanding!
I ended up doing the the flush bit, then saveall. Following that the remote connection worked. I can't tell if that's a permanent fix as it may be ok the rest of the day so I may not find out until tomorrow morning if it fails again.
However both my phone and tablet now seem unable to connect to anything even though they are connected to the wifi (I've tried rebooting, disconnecting and reconnecting to the wifi). The internet on the laptop outside the virtual desktop is also intermittent. From my reading of the instructions here http://npr.me.uk/telnet.html#dnsr10 I haven't actually made any permanent changes........?
I'd be prepared to buy a new router if I knew for sure that was going to fix this problem.
16-07-2014 12:04 PM
Quote from: francemillers I was trying to follow the note about the "intf" bit but the command "dns server forward dnsset list" just showed me an empty table. Sorry, this is all a bit beyond my understanding!
The interface used by Plusnet supplied routers / firmware is intf=Internet .
If it's of any help, you could download a telnet script to change the routers dns setting.
Works with R8 and R10 firmware supplied by PN, instruction in the readme.txt file.
http://npr.me.uk/dns-script.zip
16-07-2014 12:08 PM
That's probably ok, since there were no DNS servers set in the router when you started.
Quote but the command "dns server forward dnsset list" just showed me an empty table.
If you've done the saveall command, then the changes are permanent BUT can be undone using either the commands shown in the 'Undo, return to obtaining DNS resolvers via DHCP' section of the link OR by a factory reset of the router.
Quote From my reading of the instructions here http://npr.me.uk/telnet.html#dnsr10 I haven't actually made any permanent changes........?
Can you connect to the router and post the result of the 'dns server forward dnsset list' command please. That will check that the DNS servers have been set correctly.
Quote However both my phone and tablet now seem unable to connect to anything even though they are connected to the wifi (
16-07-2014 12:58 PM
Forwarding Servers (flags:
PP [I ]PSEC
Set Metric Flg DNS-Server EDNS Label Intf
State
0 10 P* 212.159.6.9 Inte
rnet UP
0 10 P* 212.159.6.10 Inte
rnet UP
Please note: the queries will be forwarded to all entries of a matching DNS Set
(see rules section) AND
all available entries in DNS Set 0.
16-07-2014 1:11 PM
PP [I ]PSEC
State
0 0 208.67.222.222 Inte
rnet UP
0 0 208.67.220.220 Inte
rnet UP
16-07-2014 1:26 PM
16-07-2014 3:17 PM
16-07-2014 4:07 PM
Paul
Tracing route to 10.254.0.163 over a maximum of 30 hops
1 5 ms 3 ms 2 ms dsldevice.lan [192.168.1.254]
2 37 ms 120 ms 44 ms lo0-central10.pcl-ag08.plus.net [195.166.128.189]
3 44 ms 43 ms 59 ms link-b-central10.pcl-gw02.plus.net [212.159.2.190]
4 * * * Request timed out.
5 * * * Request timed out.
6 * * * Request timed out.
7 * * * Request timed out.
8 * * * Request timed out.
9 * * * Request timed out.
10 * * * Request timed out.
11 * * * Request timed out.
12 * * * Request timed out.
13 * * * Request timed out.
14 * * * Request timed out.
15 * * * Request timed out.
16 * * * Request timed out.
17 * * * Request timed out.
18 * * * Request timed out.
19 * * * Request timed out.
20 * * * Request timed out.
21 * * * Request timed out.
22 * * * Request timed out.
23 * * * Request timed out.
24 * * * Request timed out.
25 * * * Request timed out.
26 * * * Request timed out.
27 * * * Request timed out.
28 * * * Request timed out.
29 * * * Request timed out.
30 * * * Request timed out.
Trace complete.
16-07-2014 4:16 PM
http://en.wikipedia.org/wiki/Private_network
It's not the vpn server, it may be the virtual desktop server though.
16-07-2014 5:30 PM
Should I do the trace route while running the vpn software or doesn't it matter?
Thanks, Paul
