Technicolor TG582n can't change DHCP leases
- Re: Technicolor TG582n can't change DHCP leases
14-05-2013 9:29 PM
Hi
I've just got the Technicolor TG582n and I'm trying to change the DHCP lease range from 192.168.1.64 - 192.168.1.253 to 192.168.1.7 - 192.168.1.18 but when I click Accept it reloads the page and gives the error "Action failed: could not set interface. Please try again."
Any ideas?
Also, the wireless page says 802.11b/g/n. Is it possible to force to n only?
Any ideas?
Message 1 of 4
(11,762 Views)
3 REPLIES 3
14-05-2013 10:12 PM
Are you disabling the DHCP server first?
This may help, it's for older firmware but the same principle still applies.
http://www.o2help.co.uk/change-lan-ip/
Message 2 of 4
(4,215 Views)
15-05-2013 12:18 AM
Quote from: chrish16 Also, the wireless page says 802.11b/g/n. Is it possible to force to n only?
Unfortunately not!
Message 3 of 4
(4,215 Views)
04-04-2014 10:33 PM
The reason for the error is that there is one or more active leases on that DHCP pool (not that the web interface for the router tells you this >:(). The lease needs to be flushed from the pool, using the telnet interface, thus:
dhcp server lease flush
Once you've done this, you can edit the pool settings
I found out how to do this in a PDF published on the elecon NZ site - see http://help.telecom.co.nz/ci/fattach/get/5042877/1321574458/redirect/1/filename/Changing-the-TG582n-... for details.
Good luck!
Good luck!
