TG582N Disable NAT
- Re: TG582N Disable NAT
TG582N Disable NAT
14-08-2013 6:50 PM
Despite no end of trying, and following various bit's of advice, including a branded PDF file supposedly showing how it's done, I still haven't managed to setup my TG852 so that I can make use of the router with my block of IP addresses, allowing me to assign public IP's directly to my devices.
Has anybody been able to get this to work ?
Thanks.
14-08-2013 10:50 PM
http://forums.modem-help.co.uk/viewforum.php?f=20
IIRC there's a template there to do what you require with a TG585v6. Different router but the principle will be the same.
15-08-2013 8:09 AM
15-08-2013 8:38 AM
15-08-2013 9:57 AM
15-08-2013 2:55 PM
What are you seeing?
15-08-2013 3:03 PM
