TBB Pings Graphs - issues arising
jelv
Fixes: 10
Something odd going on:
There's nothing I'm doing that would explain the high latency around 5pm nor the high latency yesterday evening.
(4am to 9:30am is because the local electricty sub-station blew up!)
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
21 REPLIES 21
Kelly
Fixes: 9
Re: TBB Pings Graphs - issues arising
It's the network problem we've had much of last week.  😕  Fixed again.
Kelly Dorset
Ex-Broadband Service Manager
Chris
Legend
Fixes: 169
We saw the increase and got Matt from Network Ops to take a look, should now be sorted (at least temporarily).
Fixes: 162
Kelly / Chris,
For these graphs to have real benefit, do you not need to know which PN gateway a user is connected to at all times?  Or do you have other TBB graphs hidden away somewhere showing ping times into each gateway?  If yes, it would be good if we could see those too please.
Gus
More if the same tonight 8pm too 9.20pm ish large spike on a few graphs, other than Steam nothing has been active on my connection tonight from 5.40pm onwards till now 11.30pm.
FTTP 500 regrade from Tues 28th November
Chris
Legend
Fixes: 169
Quote from: townman
Kelly / Chris,
It's not really as simple as just looking at the gateway due to the config of the network, it can help give us a general idea though. We can already see which gateway you're connected to by looking in our RADIUS logs.
houlton23
It's back again Sad Can one of the PN people explain what is happening please? (just interested :P)
Tracing route to google.com [173.194.41.78]
over a maximum of 30 hops:
 1     4 ms     3 ms     3 ms  netgear.houlton23.local [192.168.1.254]
 2    23 ms    20 ms    19 ms  lo0-central10.pcl-ag05.plus.net [195.166.128.186
 3    21 ms    22 ms    22 ms  link7-central10.pcl-gw01.plus.net [84.93.249.140
 4   235 ms   239 ms   242 ms  xe-8-2-0.pcl-cr01.plus.net [212.159.1.8]
 5    91 ms    58 ms    58 ms  ae2.pcl-cr02.plus.net [195.166.129.7]
 6    64 ms    59 ms    61 ms  ae1.ptw-cr02.plus.net [195.166.129.2]
 7    63 ms    67 ms    68 ms  72.14.223.32
 8    40 ms    35 ms    35 ms  209.85.252.186
 9    21 ms    22 ms    22 ms  72.14.238.51
10    25 ms    22 ms    22 ms  lhr08s01-in-f14.1e100.net [173.194.41.78]
Trace complete.
Chris
Legend
Fixes: 169
Yep, looks like it Sad
Chris
Legend
Fixes: 169
And by that, I mean we're looking at it again!
houlton23
Can we hope for a more permanent fix soon? And not sure if you saw my edit to my post but can you explain what's happening? (just interested)
Alex Smiley
Chris
Legend
Fixes: 169
I'll leave it to someone that understands the full nature of the issue to explain, but AFAIK we're closer to a fix.
RPMozley
Fixes: 13
pcl-ag02 appears to be affected too, with greatly increased latency. Just recently gateway hopped onto ptw-ag03 and latency was back to normal levels.
That's RPM to you!!
houlton23
I'm on pcl-ag05 so it could be all of the PCL gateways?
Chris
Legend
Fixes: 169
OK, for those experiencing the issues we're working with the vendors and gathering data on the problem at the moment (hence it not being temporarily fixed again tonight).
So if you're having the issue, log in to your router and disconnect/reconnect until usertools.plus.net/@gateway shows that you're not on a PCL gateway and you should be good.
jelv
Fixes: 10
Something happened this morning. At 09:30:15 the PPP link went down although there was no loss of sync. I've also had a change in the latency as shown on the graph:
