Stability options and enhanced traffic weighting
- Stability options and enhanced traffic weighting
Re: Stability options and enhanced traffic weighting
12-06-2009 10:49 PM
15-06-2009 1:44 PM
It's basically the aggressiveness of the DLM on noiser lines. So it could pontentially be a more aggressive noise hike if the line were unstable.
Dusty_Bin has kindly offered to try Super Stable for me
15-06-2009 2:25 PM
my dlm has settled down now it been at 12db for past 2 -3 weeks and its not tried to up, down noise margin since.
so its settled in the noise margin i had on adsl yet even adsl2 gives me abit more sync which i think is due to the few extra down tones that are used straight after the upload tones which adsl didnt use
17-06-2009 5:43 PM
Quote from: Lorian What technically is the difference between the various stability options? Just a target SNR hike or something more clever....?
Here are my initial results:
Before (i.e. standard):
PING 212.58.254.252 (212.58.254.252): 56 data bytes
64 bytes from 212.58.254.252: icmp_seq=0 ttl=250 time=15.0 ms
64 bytes from 212.58.254.252: icmp_seq=1 ttl=250 time=10.0 ms
64 bytes from 212.58.254.252: icmp_seq=2 ttl=250 time=10.0 ms
64 bytes from 212.58.254.252: icmp_seq=3 ttl=250 time=10.0 ms
--- 212.58.254.252 ping statistics ---
4 packets transmitted, 4 packets received, 0% packet loss
round-trip min/avg/max = 10.0/11.2/15.0 ms
Status: ShowtimeRetrain Reason: 0
Channel: FAST, Upstream rate = 1016 Kbps, Downstream rate = 6615 Kbps
Link Power State: L0
Mode: ADSL2+
Channel: Fast
Trellis: U:ON /D:ON
Line Status: No Defect
Training Status: Showtime
Down Up
SNR (dB): 9.4 5.8
Attn(dB): 43.0 22.8
Pwr(dBm): 20.4 12.4
Max(Kbps): 6012 20624
Rate (Kbps): 6615 1016
G.dmt framing
K: 207(0) 128
R: 0 0
S: 1 1
D: 1 1
ADSL2 framing
MSGc: 59 14
B: 206 127
M: 1 1
T: 1 1
R: 0 0
S: 0.9963 4.0000
L: 1662 256
D: 1 1
and after (super stable):
64 bytes from 212.58.254.252: icmp_seq=0 ttl=250 time=25.0 ms
64 bytes from 212.58.254.252: icmp_seq=1 ttl=250 time=20.0 ms
64 bytes from 212.58.254.252: icmp_seq=2 ttl=250 time=20.0 ms
64 bytes from 212.58.254.252: icmp_seq=3 ttl=250 time=20.0 ms
round-trip min/avg/max = 20.0/21.2/25.0 ms
Status: ShowtimeRetrain Reason: 1
Channel: FAST, Upstream rate = 984 Kbps, Downstream rate = 6969 Kbps
Mode: ADSL2+
Channel: Fast
Trellis: U:OFF /D:ON
Down Up
SNR (dB): 11.3 5.3
Attn(dB): 43.0 22.9
Pwr(dBm): 20.5 12.6
Max(Kbps): 8436 20118
Rate (Kbps): 6969 984
G.dmt framing
K: 218(0) 31
R: 16 14
S: 1 4
D: 32 2
ADSL2 framing
MSGc: 59 34
B: 217 30
M: 1 4
T: 1 4
R: 16 14
S: 0.9962 4.0000
L: 1879 276
D: 32 2
That looks like interleaved to me, even though it says fast.
17-06-2009 6:11 PM
You were on auto both before and after though.
18-06-2009 12:38 PM
This was initiated by BT's DLM, I guess, as it happened at the same time as yesterday:
Thu, 2009-06-18 07:33:51 - LCP down.
Thu, 2009-06-18 07:33:58 - Initialize LCP.
Thu, 2009-06-18 07:33:58 - LCP is allowed to come up.
Thu, 2009-06-18 07:33:59 - CHAP authentication success
This was accidentally initiated by me:
Thu, 2009-06-18 11:14:28 - LCP down.
Thu, 2009-06-18 11:14:36 - Initialize LCP.
Thu, 2009-06-18 11:14:36 - LCP is allowed to come up.
Thu, 2009-06-18 11:14:37 - CHAP authentication success
Upstream rate = 1001 Kbps, Downstream rate = 5539 Kbps
Mode: ADSL2+
Down Up
SNR (dB): 15.3 5.6
Attn(dB): 43.0 22.9
Pwr(dBm): 20.2 12.4
So looks like I've now been bumped up to 15 dB SNR as well
I'm pretty certain that happened on the first resync today.
18-06-2009 12:39 PM
19-06-2009 8:56 AM
Channel: FAST, Upstream rate = 1001 Kbps, Downstream rate = 2964 Kbps
Mode: ADSL2+
Channel: Fast
Down Up
SNR (dB): 22.5 5.9
Attn(dB): 43.0 22.9
Pwr(dBm): 20.0 12.4
Max(Kbps): 9588 19984
Rate (Kbps): 2964 1001
G.dmt framing
K: 45(0) 36
R: 16 12
S: 1 4
D: 64 2
ADSL2 framing
MSGc: 61 29
B: 44 35
M: 1 4
T: 2 4
R: 16 12
S: 0.4803 4.5714
L: 1016 273
D: 64 2
The framing parameters did change a bit yesterday, but today it looks like the interleaving has been increased again, although ping is still at 20mS...
If someone could point me to an explanation or definition of the ADSL2 framing parameters, it would be appreciated.
I wonder if it is doing some kind of training checks at a different level each day and will then revert to something more sensible, or whether the system just reckons the previous parameters weren't aggressive enough to be consdered 'super stable'?
23-06-2009 12:24 PM
Quote from: dusty_bin If someone could point me to an explanation or definition of the ADSL2 framing parameters, it would be appreciated.
For g.dmt:
K Value - Bytes in the DMT Frame
R Value - RS check Bytes
S Value - RS code word size in DMT frame
D Value - Depth of Interleaving
For adsl2:
MSGc Value: number of bytes in overhead channel message
B Value: number of bytes in Mux Data Frame
M Value: number of Mux Data Frames in FEC Data Frame
T Value: Mux Data Frames over sync bytes
R Value: number of check bytes in FEC Data Frame
S Value: ratio of FEC over PMD Data Frame length
L Value: number of bits in PMD Data Frame
D Value: interleaver depth
And, from looking at the data, the two sets of parameters are linked as follows:
K = B+1
R = R
S = M
D = D
Quote I wonder if it is doing some kind of training checks at a different level each day and will then revert to something more sensible, or whether the system just reckons the previous parameters weren't aggressive enough to be consdered 'super stable'?
Well, I didn't get a retrain this morning so I thought I would post a summary of the evolution over the last week since the transfer to super stable (time = n/a means that retrain didn't occur on that day):
Date: 06-16 06-17 06-18 06-19 06-20 06-21 06-22 06-23
Time: n/a` 07:31 07:33 07:35 07:21 07:26 07:35 n/a
Sync rate (kb/s)
Down 6615 6969 5539 2964 2964 2964 2964 2964
Up 1016 984 1001 1001 855 855 447 447
G.DMT framing
Down
K 207 218 174 45 45 45 45 45
R 0 16 12 16 16 16 16 16
S 1 1 1 1 1 1 1 1
D 1 32 32 64 64 64 64 64
Up
K 128 31 36 36 43 43 16 16
R 0 14 12 12 16 16 16 16
S 1 4 4 4 2 2 4 4
D 1 2 2 2 4 4 4 4
ADSL2 framing
Down
MSGc 59 59 59 61 61 61 61 61
B 206 217 173 44 44 44 44 44
M 1 1 1 1 1 1 1 1
T 1 1 1 2 2 2 2 2
S 0.9963 0.9962 0.9993 0.4803 0.4803 0.4803 0.4803 0.4803
L 1662 1879 1489 1016 1016 1016 1016 1016
Up
MSGc 14 34 29 29 19 19 64 64
B 127 30 35 35 42 42 15 15
M 1 4 4 4 2 2 4 4
T 1 4 4 4 4 4 1 1
S 4.0000 4.0000 4.5714 4.5714 3.2000 3.2000 4.2953 4.2953
L 256 276 273 273 255 255 149 149
D 1 2 2 2 4 4 4 4
I forgot to add that the ping has gone up from 10 mS to 25 mS last time I checked.
23-06-2009 12:53 PM
Looking at that, the drop in speed correlates directly with the doubling of the interleaving depth. Do you have the noise margin figures aswell?
23-06-2009 12:56 PM
Down Up
SNR (dB): 22.4 21.0
Attn(dB): 43.0 22.9
Pwr(dBm): 20.0 12.2
Max(Kbps): 9984 20624
Rate (Kbps): 2964 447
23-06-2009 12:59 PM
If it's really being a pain, let me know and I can move you back to stable.
23-06-2009 1:31 PM
I do struggle to think of circumstances where users would need or want this level of stability - could be quite useful for the ISP when customers complain too much, I suppose
How are your other trialists getting on?
When I change, I'm more likely to go back to where I was on 'standard' and play with the interleaving option, although I guess we could see what 'stable' does on the way back - anyway, let's just wait and see what happens for now.
23-06-2009 1:35 PM
Thank you very much for your help so far
25-06-2009 10:25 AM
Before I was put on a BT banded profile I too was seeing resyncs from the BT end at just after 7.30am, often for no apparent reason. It seems to be a regular thing.
That's a big drop, from around 6900 to 2900. I was wondering whether trying the 'stable' option would give me a better speed than my current 3069, but it looks like it may end up being slower. I may still give it a try, though.
It's encouraging to see that you could get a sync of 6900 with am attenuation figure of 43. My attenuation's 39 and I've never got above 5200 (I know - it's a wiring issue).
Graham
