once and for all... what are 'ideal' SNR and Attenuation figures?
- once and for all... what are 'ideal' SNR and Atten...
24-08-2009 5:04 PM
Re: once and for all... what are 'ideal' SNR and Attenuation figures?
24-08-2009 5:20 PM
24-08-2009 5:21 PM
For the SNR margin, this will change depending upon your sync speed, so it's only relevant to talk about a perfect SNR margin if you already sync at the maximum possible (8M for ADSL Max, 20MB for ADSL2+). If you are doing that and your SNR margin is greater than around 15 and you never get any errors logged I suppose you could call it perfect.
Have a read of http://www.kitz.co.uk/adsl/linestats.htm
24-08-2009 5:45 PM
I live right next door to the exchange and my cables are underground so i thought they would be ok...
Connection Speed 8064 kbps 448 kbps
Line Attenuation 2.0 db 1.5 db
Noise Margin 9.7 db 24.0 db
is there anything i can do to improve my noise margin?
24-08-2009 5:47 PM
24-08-2009 5:48 PM
24-08-2009 5:49 PM
24-08-2009 5:50 PM
Quote from: Oldjim Try connecting to the test socket
... and unplug all phones and other equipment so you only have the ADSL modem on the line.
24-08-2009 5:52 PM
24-08-2009 5:53 PM
24-08-2009 5:55 PM
Quote from: nolluwhereilive is there anything i can do to improve my noise margin?
No, and why would you?
The noise margin is what it is because you are so close. The signal power is probably reduced anyway due to the very short cable.
ADSL2+ would be good.
24-08-2009 6:01 PM
24-08-2009 6:02 PM
24-08-2009 6:05 PM
Thanks for everyones input
24-08-2009 6:06 PM
