Speed problems
- Speed problems
Speed problems
15-02-2013 12:53 PM
Hi, Is there a problem in the network or at our exchange I wonder?
Normal speeds of 1Mbps up and 10+Mbps down have gone totally with <2Mps down, .5 to .9 up.
Router and cabling checked here - no changes either.
Router PPoA dropped/restarted to gateway hop - no difference
Router rebooted - no difference.
Router Stats (Draytek 2850vn) showing good sync rate and SNR - 16Mbps dl, 1 Mbps ul, and 3 SNR. Line attenuation normal for this line at 26.
ATM Statistics TX Cells RX Cells TX CRC errs RX CRC errs
220260 1641989 0 38747
All PCs on LAN sufering equally so not a local system problem. LAN performance is fine, only the WAN is suffering.
Help!?!
Help!?!
Message 1 of 3
(641 Views)
2 REPLIES 2
Re: Speed problems
15-02-2013 5:09 PM
There's nothing reported.
Can your run a speed test at http://speedtest.btwholesale.com and run further diagnostic after the test has completed.
Check which gateway you're on at http://usertools.plus.net/@gateway/
Run a pingpath command, to run the pingpath command you'd need to open a command prompt and type the following, 'pathping ntp.plus.net -q 50'
Message 2 of 3
(293 Views)
Re: Speed problems
25-02-2013 12:45 PM
It looks like it may be due to <a href="http://community.plus.net/forum/index.php/topic,111170.0.html">this</a>.
If it happens again can you run through a few checks so we can see what is going on?
Chris
Chris
Message 3 of 3
(293 Views)
