Speed much lower than estmated speed..
- Speed much lower than estmated speed..
Re: Speed much lower than estmated speed..
02-02-2013 8:10 PM
Thank you for getting back to us. I am sorry to hear that the issue with your speed is still ongoing.
I have tested your connection and I could see that the speedtest you performed failed.
So we can check whether our internal network is causing the problem we will require that you perform the second and third BT speed tests.
To do these you will need to re-run the BT speedtester however once this has complete,
should you get less than the required level the test should fail and give you the option of running further tests.
Please follow the instructions below to complete test.
Instruction for Fibre setup to modem
• Plug the Ethernet cable in to the BT modem and the PC
• Switch the BT modem on
• The setup is done as follows; create a dial-up PPPoE connection.
• Go to Control Panel -> Network Connections
• Create a new connection
• Connect to the Internet
• Set up my Connection Manually
• Connect using a broadband connection that requires a username and password (PPPoE)
• ISP Name – Plusnet
• Enter the broadband username:speedtest@speedtest_domain
and password: testing
• Finish and click connect
If you use Windows 7 it will try and test the connection during the setup;
this will fail and give you an error. Click Skip or Continue and then after clicking finish right click the new connection
icon and click properties.
Under Service Name enter Plusnet then click OK. Then double click the new connection icon and click connect.
Once successfully logged in, you can access the Speed Tester server by typing http://217.32.105.42 in your browser.
To initiate a test, you must type in your phone number in the available prompt box and press ‘Go’.
(This is used to identify your test and allow BT to investigate any faults)
I followed it word by word and here is what I get:
System is busy.Please try again later.. This is inspite of numerous trials...
04-02-2013 10:08 AM
hope they look at it today....
04-02-2013 2:42 PM
04-02-2013 3:05 PM
Sorry for the delay, I'm getting this picked up with our faults team, we'll be in-touch shortly.
04-02-2013 3:58 PM
quoting a reply to me from TBB forum:
"I just tried it and get the same issue when connecting with the BT speedtest@speedtest_domain test account. However it works perfectly when testing via Plusnet's network. Perhaps when BTW implemented its new speedtester they've misconfigured something and the resources needed to perform the download and upload tests aren't accessible from the BT test account."
maybe thats why i cant complete the tests suggested by PN on my ticket.
04-02-2013 4:40 PM
04-02-2013 5:09 PM
and once i hit this link [http://217.32.105.42/] it will attempt to start from TAP1 anyway.
thats when i get the sytem busy message of which i have posted a screenshot.
and as soon as i disconnect from the test account, plug the modem to router,connect using my plusnet account I can do the BTW test .
so it seems BTW is not allowing tests with the test account anymore...
04-02-2013 5:10 PM
I haven't raised any faults so no login expected on test domain. But... I was able to log in to the test domain and set up PPoE session, get an IP address, gateway and DNS servers via DHCP and connect to the test server at http://speedtest.btwholesale.com/ It allowed me to start the test, but the test fails at the point where it tries to download test files to the client browser in order to measure throughput. Not sure if this is what you're expecting? I wondered if the test files were located on a different server that's not accessible from this test domain, but just a wild guess
04-02-2013 5:20 PM
Quote from: Bright
thanks mate for chipping in..
that's exactly where it gets stuck for me too...
04-02-2013 5:31 PM
05-02-2013 9:47 AM
05-02-2013 10:00 AM
Thanks. The problem seems to be that the BTW speed tester site doesn't actually work when logged into the BT test domain (speedtest@speedtest_domain)
05-02-2013 10:14 AM
Please read this post too ... I have followed your faults departments latest instructions and it doesnt even complete a downstream speed test...
http://community.plus.net/forum/index.php/topic,110849.msg956300.html#msg956300
05-02-2013 5:17 PM
In general as a response to all, it seems to depend on the difference between sync speed and throughput as to whether a TAP3 test is requested or not, and it only works on the downstream side of things from what we know - even if upload is affected, it won't request a TAP3.
Hope that helps some.
07-02-2013 10:16 AM
4:53pm, Tuesday 5 Feb 2013
A line reset and engineering visit is needed here after looking at the line for Matt.. Downstream and upstream both lower than expected with the recent drops..
Kind regards,
can someone look into it and arrange an engineer appointment for me please?
