Spam filtering
peaksoft
Spam filtering
I'm very concerned about the number of false positives in the spam filtering.
Webmail is set to forward my mail to Outlook Express, but a couple of times a day, it's necessary for me to log on to webmail, go into the spam folder, and weed out three or four messages that are definitely not spam.
Although I toggle them as Not Spam, so that they are then transferred to the Inbox, then forwarded, the webmail program doesn't seem to learn.
25 REPLIES 25
Oldjim
Resting Legend
Fixes: 63
Re: Spam filtering
Is it possible to whitelist the addresses or even the domains.
That is the solution I used and it seemed to work
Anotherone
Champion
Fixes: 21
Re: Spam filtering
Also Login to the Member Centre Manage My Mail (hope I got the link right!), select the Spam Tab.
Change the setting "How would you like us to deal with messages identified as spam?" to 'Move to Inbox'.
That way you won't have to keep logging into webmail. If you're concerned about false positives, you should also turn off the Edge Protection to see how it goes. But if the amount of actual Spam you get is excessive you may wish to resort back.
As Jim has suggested, Whitelist any regular email addresses that are giving you difficulty. Personally I find it extremely irritating that Postini continues to treat mail from authenticated addresses as Spam and from addresses I have continually reported as NOT Spam Angry
pierre_pierre
Re: Spam filtering
another thing about false positives is to remember that one mans good mail might be another mans junk, and no matter how much you report it as not spam will not change that, just whitelist it
madjbright
Re: Spam filtering
Quote from: pierre_pierre
one mans good mail might be another mans junk .......
Yes, but the things that I want to receive and which get marked as Spam come from legitimate sources that I have subscribed to and which can safely be unsubscribed from. Therefore these should not be considered as Spam. Others who do not want them can unsubscribe.
pierre_pierre
Re: Spam filtering
trouble is the internet is not full of intelligent people, unsubscribing is too easy.
some times that is, I was subscribed to an e-mail for about two year, it still got delivered when I changed my main name from free-online to idps to me.uk,  when I wanted to unsubscribe, The other half kept sending linked messages and still got the e-mails, she was realy getting annoyed until I looked and realised she was sending from me.uk to a list for idpss  I had stopped the other outputs.  Had to phone the company and get it done manually, luckily a free call
bobpullen
Fixes: 316
Re: Spam filtering
You could use IMAP to collect your mail too. That way your Spam folder will be accessible from within Outlook Express.
Denzil
Re: Spam filtering
Quote from: madjbright
OK, you know that, but Postini can't necessarily tell if a particular source is legit or not. It has to deal with a large number of emails, all different kinds of messages from different people, so it can only make its decisions based on general information. For example, two doctors might quite reasonably discuss Viagra, but most emails on the subject are spam, so it difficult for a spam filter to tell the difference.
SteveA
Re: Spam filtering
My brother had so many real emails flagged by Postini as spam that he turned off all the filtering. It had decided that every legitimate email he gets from Paypal and Ebay was spam as were marketing emails from legitimate companies and it didn't seem to want to take any notice of him telling it that they weren't . I know its important to stop spam but Postini seems to be paranoid about it, and apparently it doesn't listen to you telling it that it is wrong.
Lolaan
Re: Spam filtering
It's the same here. I cannot make Postini accept that anything coming from hmv.com is genuine and not spam, that's not too bad but sometimes it's  intercepting emails sent from sellers and buyers from Ebay and mark them as spam, which can create problems. I do check my spam folder regularly just for those mistakes.
Oldjim
Resting Legend
Fixes: 63
Re: Spam filtering
Just add hmv.com to the white list here similar for paypal and ebay
Lolaan
Re: Spam filtering
It says that the white list feature  is not available with my current account and to upgrade. So that is that. Sad
Oldjim
Resting Legend
Fixes: 63
Re: Spam filtering
What account are you on.
SteveA
Re: Spam filtering
OK can anyone explain why the plusnet system has decided that the following email is spam? I've included the bottom part of the headers which include the DSPAM tags from my own email server which uses plusnet as a relay host.
Date: Mon, 04 Aug 2008 19:41:54 +0100
Message-ID: <k8je941din7sgsbqn01c4q1sa1s64upvlp@4ax.com>
X-Mailer: Forte Agent 4.2/32.1118
MIME-Version: 1.0
Content-Type: text/plain; charset=us-ascii
Content-Transfer-Encoding: 7bit
X-DSPAM-Result: Whitelisted
X-DSPAM-Processed: Mon Aug  4 19:41:54 2008
X-DSPAM-Confidence: 0.9979
X-DSPAM-Probability: 0.0000
X-DSPAM-Signature: 48974d7239577923088037
X-Plusnet-Relay: e9a06ec8bd7371fc0048c9fba6e295f1
X-pstn-neptune: 35/35/1.00/87
X-pstn-levels:     (S: 1.13784/99.90000 CV:99.0000 )
X-pstn-settings: 1 (0.1500:0.1500) cv gt3 gt2 gt1
X-pstn-addresses: from <steve@my.domain.here> [db-null]
X-pstn-neptune-cave-rslt: qtine
X-pn-pstn: Spam 1
X-PN-Spam-Filtered: by PlusNet MXCore (v4.00)
Subject: [-SPAM-] templating system
Can you remind me what the templating system is called again?
Thought I'd remind you of the URL for the canalplan system on this box
which is canalplan.tty.org.uk
and the blog is at
http://canalplan.blogdns.com/canalplanac/
That was an email sent from me to my brother (also on Plusnet) and he tells me that the web interface will not allow him to go in an mark it as NOT SPAM.
When a Spam system decides, for no good reason that ham is spam and refuses to let you tell it otherwise then it becomes as annoying as having to wade through the spam in the first place because if you have to wade through the flagged as spam items to find the ones that ARENT spam then ....
Anotherone
Champion
Fixes: 21
Re: Spam filtering
Simple - it's got just a few words of text and a link in it. As this follows the "general" profile of many spam messages Postini treats it as spam and gives it an unduly low score. They seem obsessed with looking only at the content and not checking the validity of the source even when you've told them (multiple times) it's not spam.
A lot of messages my friends send are of this format and it has irritated many of us to the point of switching off certain parts of the filtering. Whitelisting seems to be the only solution.
In this particular case as the score is not high but seems to be above the threshold of your settings, it's going to be interesting to see what PN have to say.
