Slow Speed
- Slow Speed
Re: Slow Speed
10-04-2009 8:43 PM
Re: Slow Speed
10-04-2009 8:46 PM
Quote from: Oldjim Go on - enlighten us - what are the router stats
System Up Time 02:53:20
Port Status TxPkts RxPkts Collisions Tx B/s Rx B/s Up Time
WAN PPPoA 1751 1876 0 1862 2573 00:06:25
LAN 100M/Full 26132 35124 0 1386 774 02:53:16
ADSL Link Downstream Upstream
Connection Speed 5376 kbps 448 kbps
Line Attenuation 37 db 8 db
Noise Margin 9 db 24 db
Re: Slow Speed
10-04-2009 8:47 PM
Re: Slow Speed
10-04-2009 9:07 PM
Normal
Connection Speed 3584 kbps 448 kbps
Line Attenuation 36 db 8 db
Noise Margin 4 db 24 db
Test Socket
Your sync speed has increased from 3584 to 5376 with an increased noise margin. This increase in noise margin isn't unusual as what probably happened is that the results from the normal socket were from a last sync in the late afternoon/early evening and it synched at 3584 kbps with a noise margin of 9dB which subsequently reduced to 4dB as it got dark (noise margin usually drops under those conditions - but not as much as this)
To simplify - using the test socket increased your synch speed by a significant amount and if you did a resynch in the day time from the test socket it would be even higher.
What does this tell us - the problem is with your internal wiring unless it changes when you plug the phone in.
Are there wires attached to the rear of the part of the socket you unscrewed and how many are there.
Re: Slow Speed
10-04-2009 9:38 PM
Plugged phone back in and there are four wires at back of the plate there is a black wire but not connected.
Here are the results once I plugged the phone back in
System Up Time 03:44:58
WAN PPPoA 1832 1928 0 1338 2600 00:06:53
LAN 100M/Full 36122 47840 0 1477 869 03:44:54
Connection Speed 2720 kbps 448 kbps
Noise Margin 3 db 24 db
Re: Slow Speed
10-04-2009 9:41 PM
Re: Slow Speed
10-04-2009 9:52 PM
System Up Time 03:58:06
WAN PPPoA 490 494 0 1925 3228 00:01:15
LAN 100M/Full 39699 51844 0 1570 897 03:58:02
Connection Speed 4928 kbps 448 kbps
Noise Margin 10 db 24 db
adie:quote
Re: Slow Speed
10-04-2009 10:13 PM
Lets ask the obvious question first.
Do you have anything plugged in to the extension wiring such as a Sky box, another phone, fax machine, monitored alarm system
If you have a digital camera can you take a picture of the back of the removable part of the faceplate and post it here. If you don't knoew how to select Additional Options and then browse to the picture on your computer - the screen looks like this
Re: Slow Speed
10-04-2009 11:31 PM
Here is the photo of the backplate. I have sky but that's in the other room.
Re: Slow Speed
11-04-2009 10:06 AM
You appear to have 4 wires connected to different terminals in the faceplate.
Ideally you should only have two connected - as the ring wire isn't needed and can cause interference but not usually to the extent you are seeing.
The wires you need connecting are the one to connections 2 and 5 as they carry the signal to the phones and router etc. This link explains it http://www.adslnation.com/support/extensions.php
Re: Slow Speed
11-04-2009 10:12 AM
Morning Jim Yes the sky is connected to a filter in the other room which has been the case for some years.
Quote from: Oldjim But is the Sky box connection to the phone line filtered
Regards
Re: Slow Speed
11-04-2009 10:16 AM
Re: Slow Speed
11-04-2009 10:20 AM
I can see that you have 2&5 connected (Blue/White & White & Blue) as you also have 3&4 connected as well which is your ring wire which is prone to pick up RFi (it's effectively a antenna)
Could be worth disconnecting 3&4 from all your extensions and seeing how things are then IMO - Jim maybe could correct me if I'm wrong.
EDIT: DOH - spent so long composing my post, Jim got there before me...
Re: Slow Speed
11-04-2009 10:27 AM
Re: Slow Speed
11-04-2009 10:53 AM
Below results from main socket with sky connected.
System Up Time 00:53:06
WAN PPPoA 3381 3721 0 676 1289 00:25:40
LAN 100M/Full 7759 10560 0 1356 757 00:53:02
Connection Speed 3968 kbps 448 kbps
Noise Margin 13 db 26 db
Without the sky connected
System Up Time 00:48:21
WAN PPPoA 3333 3656 0 824 1576 00:20:55
LAN 100M/Full 7691 10188 0 1485 820 00:48:17
Noise Margin 14 db 26 db
Regards
