Slow Speed
- Slow Speed
- « Previous
- Next »
Re: Slow Speed
17-04-2009 11:53 PM
Hiya
Thanks for your Pm,
Here are the results taken 11.45
System Up Time 14:51:30
Port Status TxPkts RxPkts Collisions Tx B/s Rx B/s Up Time
WAN PPPoA 35935 43190 0 149 544 14:34:43
LAN 100M/Full 46790 94549 0 589 248 14:51:26
ADSL Link Downstream Upstream
Connection Speed 5024 kbps 448 kbps
Line Attenuation 37 db 8 db
Noise Margin 2147483646 db 24 db
Noise Margin seems to do this most nights now but there again I didn't do the stats before this last week, I only ever checked speed.
I have checked the other extension sockets with corded phone No dialing tone. Sky cable not connected
Regards Wattsy
Message 136 of 143
(503 Views)
Re: Slow Speed
18-04-2009 12:35 AM
Obviously the wire from Master to first extension then.
There seems to be a noise issue hear to sort, is there any audible noise on the line, you haven't mentioned that? At least the sync is hanging on at the moment.
Message 137 of 143
(503 Views)
Re: Slow Speed
18-04-2009 6:52 PM
Hiya
Sorry I have got back before now just been one of those day.
Results 09.00 this morning router had been powered down overnight.
System Up Time 00:01:13
WAN PPPoA 346 353 0 1134 4546 00:00:51
LAN 100M/Full 650 681 0 5109 1563 00:01:09
Connection Speed 5056 kbps 448 kbps
Noise Margin 11 db 24 db
Results when plugged into master test socket, taken this morning 09.30
System Up Time 00:06:15
WAN PPPoA 145 120 0 1226 400 00:00:35
LAN 100M/Full 2599 2704 0 3769 1570 00:06:11
Connection Speed 5728 kbps 448 kbps
Noise Margin 15 db 25 db
Taken once connected back into main socket
System Up Time 00:15:21
WAN PPPoA 7 4 0 20 34 00:00:14
LAN 100M/Full 5903 5984 0 4263 1404 00:15:17
Connection Speed 4928 kbps 448 kbps
Noise Margin 10 db 26 db
Results 14.00 this afternoon
System Up Time 05:25:11
WAN PPPoA 1912 1887 0 17 37 05:10:04
LAN 100M/Full 8322 27185 0 243 154 05:25:07
Noise Margin 8 db 26 db
Results 18.30 this evening
System Up Time 09:43:57
WAN PPPoA 3506 3590 0 119 263 01:54:46
LAN 100M/Full 15616 47903 0 253 160 09:43:53
Noise Margin 9 db 26 db
There doesn’t appear any noise on phone line other than clear dialling tone.
Regards Wattsy
Message 138 of 143
(503 Views)
Re: Slow Speed
18-04-2009 9:38 PM
Hi Wattsy,
well, we all have days like that!
0930 this morning, now those figures in the test socket are starting to indicate the potential of your line, but I'm not sure which attenuation figures to believe. When plugged back into the master, the noise level has increased, ie the margin reduced most likely because of the break in the wire and only one leg is connecting (this also suggests the break is at or near the master end).
We've had some variation in the test socket as well, so I think it's about time we considered trying another modem/router to compare. There is so much variation going on and a bit of inconsistency, we've got to narrow it down a bit. Do you have a spare or can you borrow one?
Message 139 of 143
(503 Views)
Re: Slow Speed
18-04-2009 10:15 PM
Hiya
No I haven't another router, I just have the Dynamode PCI modem and a speedtouch 330. Can't think of anyone who I could borrow one.
I have been looking on the internet for an easy way to create an extension from the master socket to my living room socket. Then I would take
the faulty extension wire out altogether.
Regards Wattsy
Regards Wattsy
Message 140 of 143
(503 Views)
Re: Slow Speed
19-04-2009 12:01 AM
Just use the green pair as I suggested in my PM, otherwise if you want to replace the cable you need the appropriate length of 2pair cable to spec.CW1308. This should be readily available at anywhere that does decent telecoms bits. (2 pair - ie 4 wires it'll be a blue pair and an orange pair). As you know you just need to use the blue pair. But really, don't worry about using the green pair in the current cable - it's your cable (not BT's) anything down stream of the master socket is your responsibility, you could use lightung flex for all anyone cares - no good for broadband though!!
I'll post back about the modem.
Message 141 of 143
(503 Views)
Re: Slow Speed
19-04-2009 12:33 AM
Try the Speedtouch. Make sure you've got the latest drivers. All the info you need is in that link from reply #5 from Oldjim on the first page of this thread. We need a comparative set of stats.
Message 142 of 143
(503 Views)
Re: Slow Speed
19-04-2009 12:55 AM
Hiya
Here are some results for 00.45 with extension wire removed from master socket
System Up Time 00:02:38
WAN PPPoA 506 514 0 665 1794 00:02:16
LAN 100M/Full 773 751 0 2357 894 00:02:34
Connection Speed 4832 kbps 448 kbps
Noise Margin 11 db 25 db
I couldn't get the stats when the speedtouch was installed
I will send you a pm
Regards wattsy
Message 143 of 143
(503 Views)
- « Previous
- Next »
