Router QoS...what are my bandwidth settings?
- Router QoS...what are my bandwidth settings?
14-01-2013 12:28 PM
I'd like to make use of the QoS facility in my Asus RT-N56U router. It wants me to enter my upload & download bandwidth settings. Would someone at PN please be kind enough to supply me wth them? Thanks, Nick
Message 1 of 6
(2,130 Views)
5 REPLIES 5
Re: Router QoS...what are my bandwidth settings?
14-01-2013 12:30 PM
If your router does not know your upload and download bandwidth then you do not have an internet connection.
Message 2 of 6
(975 Views)
14-01-2013 12:34 PM
If it's a separate router using a PPPoE connection (such as with fibre), I don't think the router is aware of the line rate. That's how it is on my Draytek - internal modem, QoS set automatically; separate modem, QoS has to be set manually.
Assuming you're on fibre, I'd go to the BT Wholesale speed checker and get the IP profile off there.
Message 3 of 6
(975 Views)
14-01-2013 1:36 PM
That's eactly my situation CX, thanks for the advice.
dick:quote
dick:quote
Message 4 of 6
(975 Views)
14-01-2013 2:12 PM
the n56u isnt aware...i know because i had the same issue.
you need to know your upload speed and then enter that or higher in the box.
if you dont know what it should be just enter something silly like 25mbs and do a speed test.....it will give you your upload figure.
Message 5 of 6
(975 Views)
14-01-2013 2:25 PM
Thanks Flaminroses, I think I have it now. There are so many features in this router & I'm gradually getting to grips with them all.
Message 6 of 6
(975 Views)
