Port 25 blocked
- Re: Port 25 blocked
Port 25 blocked
09-12-2007 8:17 PM
It appears as though port 25 has become blocked on one of my referrals acounts who I support. What can be done to resolve this ASAP?
Graeme.
Graeme.
Message 1 of 6
(2,016 Views)
5 REPLIES 5
Re: Port 25 blocked
09-12-2007 8:24 PM
This is usually due to antivirus or firewall upgrades being applied incorrectly (generally by the program, not the end user). It's usually worth reinstalling and then reupdating the software, when I've had this problem (I use AVG free) this has solved it.
Hope that helps,
Hope that helps,
Message 2 of 6
(585 Views)
Re: Port 25 blocked
09-12-2007 8:37 PM
Cheers mate, will try that.
Message 3 of 6
(585 Views)
Re: Port 25 blocked
10-12-2007 9:35 AM
No Dice, uninstalled AVG completely, reset and nothing. As this is applying to both external mail accounts and Plus Net Accouns, I am guessing it must be due to the connection. OE is being used so is throwing up all sorts of errors, generally 0x800ccc6f which is mail transaction failed error codes. Please advise.
Message 4 of 6
(585 Views)
Re: Port 25 blocked
10-12-2007 9:48 AM
I suggest you try testing using telnet which may give you a better picture of what's happening:
Tutorials & FAQs: Servers: Telnet as a Diagnostic Aid
The part you need is headed Checking the SMTP server
Message 5 of 6
(585 Views)
Re: Port 25 blocked
10-12-2007 4:55 PM
Tracked it to something else entirely, all sorted now, thanks for your help.
Message 6 of 6
(585 Views)
