Phone socket
adrian001
Phone socket
How much would it cost to put a bt socket in
12 REPLIES 12
Legend
Fixes: 255
Re: Phone socket
Is this just a replacement, or an extension, or a new line?
adrian001
Re: Phone socket
This is a new socket that goes in the lounge. There is already one in the Hall.
Legend
Fixes: 255
Re: Phone socket
So, in effect you are wanting an extension? Sorry for a further question, but what type of master socket have currently got? - a photograph would be very helpful.
adrian001
Re: Phone socket
A new outreach socket
Legend
Fixes: 255
Re: Phone socket
You mean a Master Socket 5C with a Mk4 faceplate?
Gel
Aspiring Champion
Fixes: 29
Re: Phone socket
If diy competent, no reason you can't fit yourself to save on OpenReach's high charges.
Or look in local rag; many ex O/Reach engineers advertise their services there.
Or a sparkie can do.
https://www.ebay.co.uk/itm/20m-2-PAIR-BLACK-External-Telephone-Cable-Extension-Kit-copper-tool-socke...
Legend
Fixes: 255
Re: Phone socket
@Gel Agreed, but if it is a 5C with a filtered faceplate, I think the OP may run into problems fitting an extension.
When they reply with the socket/faceplate models, I will be passing this to a couple of the more knowledgable 'telephone guys' - it is a little way outside my comfort xone.
adrian001
Re: Phone socket
How much would it cost to extend a phone line?
It is a master socket 5c.
198kHz
Fixes: 41
Re: Phone socket
Assuming it's actually a standard phone-only extension socket you require, the answer is - very little.
This guy knows his stuff, and will guide you through it.
Otherwise, a local independent (often one man band and ex-BT/Openreach) comms engineer will do it for a reasonable price.
As a last resort, you could ask Plusnet to arrange the job with Openreach. Can't quote any figures, but it'll be in the arm and a leg territory.
Murphy was an optimist
Zen FTTC 40/10 + Digital Voice   FRITZ!Box 7530
BT technician (Retired)
LordFoul
Fixes: 32
Re: Phone socket
HI @adrian001,
Thanks for getting in touch, I appreciate your query.
In answer to your question, an Openreach engineer call-out is roughly around £180 although this is not a quote. As advised by @ 198kHz , you'll probably find some one local who could do it a lot cheaper.
Thanks - LF
pint
Re: Phone socket
[quote]A new outreach socket [/quote]
Do you mean Openreach?
Adding an extension is incredibly easy to do yourself no different to running an extension lead for the mains.
What do you intend to plug into the extension?Huh
adrian001
Re: Phone socket
It is ok thanks. All sorted now.
