Migration advice
- Migration advice
Migration advice
18-09-2008 5:54 PM
Hi
My connection is due to go live tomorrow.
When I have moved provider before I generally terminate my session with the provider I am leaving the night bfore before I go to bed, put in the new details and click connect so that the router can log in as soon as the migration is complete.
Anyone see any problem with this strategy?
Message 1 of 8
(1,418 Views)
7 REPLIES 7
Re: Migration advice
18-09-2008 6:06 PM
You may be off air longer than you need to be.
I was logged in using my BT Broadband connection and working happily when Plusnet rang me about delivery of my new router. "so you went across this morning.." they said. "Did I? I am still connected to BT" I replied. I changed the router connection details reconnected and I was with Plusnet. Less than 10 minutes down time.
Why not continue using your old ISP until it stops working THEN change your settings to Plusnet?
Message 2 of 8
(540 Views)
18-09-2008 6:12 PM
I'm off tomorrow and tend to sleep in until around 12ish so thats why I intend to do it.
Cheers for the advice.
Message 3 of 8
(540 Views)
19-09-2008 12:31 AM
Quote from: alanf Why not continue using your old ISP until it stops working THEN change your settings to Plusnet?
That's the approach most people take.
Make sure you have a note of your new login details though so you don't find yourself with no connection all of a sudden (also the approach most people take ;D)
It's not going to cause any "harm" either way though.
Message 4 of 8
(540 Views)
19-09-2008 2:53 AM
When I migrated I was working away and my connection dropped but I could not put my new details in as the email from Plusnet with these details was sent out about an hour later.
Message 5 of 8
(540 Views)
19-09-2008 3:14 AM
I had my configuration email from PN several days before I migrated, and I was worked uway on the old ISP until it stopped working.
Just put id and password into router, and I was back online with PN in a matter of minutes.
Message 6 of 8
(540 Views)
29-09-2008 9:46 PM
Just to update this thread
After a bit of a bumpy start thanks to bit of wayward router firmware, I'm now happily surfing away on Plusnet and am glad I made the switch.
Message 7 of 8
(540 Views)
30-09-2008 7:25 AM
Nice one.
Welcome aboard Mitch
Message 8 of 8
(540 Views)
