Just connected to fibre and speeds are far lower than speeds quoted on order!!
- Just connected to fibre and speeds are far lower t...
- « Previous
- 1
- 2
- Next »
Re: Just connected to fibre and speeds are far lower than speeds quoted on order!!
20-02-2013 8:32 PM
how are you connected to your router, if not already trying plugging in with a ethernet cable and do a test, also doing speedtest at peak time will not give you a good result!
Message 16 of 20
(230 Views)
20-02-2013 8:33 PM
Connected by wifi , exactly the same results with ethernet
Message 17 of 20
(230 Views)
21-02-2013 1:05 PM
Hi there, I can see the fault is back with our faults team - there should be an update on there for you soon.
Message 18 of 20
(230 Views)
21-02-2013 10:03 PM
Any Better Matt??? Get ours fitted tomorrow hopefully...thats if they dont mess that up as well..still waiting for router(good job I purchased one anyhow i say)..
Message 19 of 20
(230 Views)
22-02-2013 9:48 AM
Its getting worse if anything. BT Wholesale test now shows 31mb down and 4mb up. When it was first installed it was doing 38 down and 6 up and working fine. Why the speed drop?? And why not the 46/6 I was promised in the order as my neighbours have called up and been told they can get that. Can somebody please look into this or I may have to cancel
Message 20 of 20
(230 Views)
- « Previous
- 1
- 2
- Next »
