Check SNR?
mattprince
Check SNR?
How do I check the SNR on the techniclour router?
Matt
Fixes: 62
Re: Check SNR?
mattprince
Re: Check SNR?
That just brings up the following...
wykehamhouse
Re: Check SNR?
You are on fibre to the cabinet (FTTC) and you will be unable to get your line stats via the Techniclor TG582N router. The only way to get the SNRM values is to hack the fibre modem, which is explained here: http://huaweihg612hacking.files.wordpress.com/2011/11/hg612_unlock_instructions_v1-3.pdf. Get the firmware from here: https://docs.google.com/folder/d/0B6wW18mYskvBZDE0YmNkMzAtZmEzMC00MjhiLTk2N2ItNDNhYTNjOGJlZTBj/edit?hl=en_US
