Is this site blocked? www.djbw.com
- Re: Is this site blocked? www.djbw.com
05-01-2011 10:54 AM
I cannot access www.djbw.com. ;
http://www.downforeveryoneorjustme.com/ says it's just me. Unlikely to be DNS as http://66.228.116.197 doesn't work either, no ping, nothing.
A traceroute shows
traceroute to www.djbw.com (66.228.116.197), 30 hops max, 60 byte packets
1 login.router (192.168.2.1) 1.050 ms 1.175 ms 1.752 ms
2 lo0-central2.pcl-ag05.plus.net (195.166.130.35) 39.598 ms 41.757 ms 43.582 ms
3 gi7-8-521.pcl-gw01.plus.net (84.93.254.57) 44.117 ms 45.219 ms 47.638 ms
4 po4.pcl-gw02.plus.net (212.159.1.129) 44.255 ms !H * *
Any thoughts?
A traceroute shows
Any thoughts?
Message 1 of 9
(1,476 Views)
8 REPLIES 8
05-01-2011 11:03 AM
looks to be a PN issue, I can get to it from my work connection but not from my PN one.
Message 2 of 9
(851 Views)
05-01-2011 11:15 AM
Thanks for checking, looks like I'll have to open a ticket, unless an admin spots this thread.
adie:quote
adie:quote
Message 3 of 9
(851 Views)
05-01-2011 11:25 AM
HI saxicola,
We have been testing this also and I have now raised a problem (ID 65155) to have this resolved. The site is not being blocked, we're just not sure at the moment why some of us can access it and some can't.
Jojo
Jojo
Message 4 of 9
(851 Views)
05-01-2011 11:43 AM
Thanks Jojo. I shall await further developments.
Message 5 of 9
(851 Views)
05-01-2011 12:27 PM
JoJo did you pick up that it is gateway related?
those of us on
You are currently connected to the gateway known as ptn-ag01.
This is located in Telehouse North.
dont have a problem
those of us on
dont have a problem
Message 6 of 9
(851 Views)
05-01-2011 2:50 PM
OK now. Thanks to whoever for doing whatever.
Message 7 of 9
(852 Views)
05-01-2011 2:56 PM
HI saxicola,
I was just about to tell you the same. There seemed to be an issue with the routing config across a couple of the gateways.
Jojo
Jojo
Message 8 of 9
(852 Views)
05-01-2011 8:08 PM
Seems to be related to this post also (although different site): http://community.plus.net/forum/index.php/topic,92018.0.html
Regards,
Jonny.
Regards,
Jonny.
Message 9 of 9
(852 Views)
