Connection password reminder
Cameleon
Is it possible to get a reminder of the password used for connection (for the router)? I havent touched my router in a few years and getting FTTC tomorrow so new router will be going in with it. Am I right in thinking its the same password as you use to log into the Portal? (obviously different username which I have from the connection settings page)  Embarrassed
Fixes: 62
Re: Connection password reminder
Yes it is the same one as used for the portal
Cameleon
Brilliant - thanks for the reply, had a feeling it was from the last time I replaced the router. Hope the change to FTTC goes as smoothly  Grin
