I ( use to ) want to quit trial
- Re: I want to quit trial
29-04-2009 3:22 AM
29-04-2009 9:26 AM
pings on belkin
is any one else getting these evening high unstable pings on the thn-ag2 box or this local BTw 21cn problem iam getting?
29-04-2009 1:34 PM
place your bets now for what time latency goes through the roof
iam offering good odds up in till 9pm
29-04-2009 1:37 PM
It'll make the ping keep going until you stop it, rather than having to do it in blocks of 4.
29-04-2009 1:39 PM
edit how do you stop it bbc will block my ip soon
edit2 crtl+c to stop
29-04-2009 5:47 PM
Quote from: ASBO hum.
had some issues gaming again tonight.
and no its not the xbox as i have tried 2
Since i moved to ADSL2 i have had numerious gaming issues and i play gear of war 24 - 7, this is know for lag. When on ADSL i had the best connection going, never had issues.
Now looking at moving to virgin media, 50 meg down - 1.5 up
29-04-2009 9:06 PM
Quote iam offering good odds up in till 9pm
i predict riot
spot on 9pm and iam starting to see the start of the decline 8.30 pm was fine
30-04-2009 12:52 AM
court is now in session, all rise for the judge asbo dog.
iam now 99% sure this is a PN trial capicity issue
i will post all my findings when pings drop back down again.
before PN see the evidence i would like to point out this is not just a midnight problem on thn-ag2 adsl2+ as i have sat with my laptop by my side pinging the thn-ag2 gateway all night why i was on the xbox.
all was fine from 9pm till 11pm and for 10 mins after 11pm i saw the same spikes in pings coupled with lag and a poor kill/death ratio would this be due to rate limits being upped abit at this time?
Any way i will post my ping captures from before and just after midnight and post the rest when i find what time they go back to normal
p.s if you cant tell iam no longer on xbox due to this and trying to amuse my self with this post
hope you find it funny 10mb+ syncers because your next in the dock
30-04-2009 9:54 AM
There's comparitively more bandwidth available for our ADSL2+ users. Sure, P2P rate limits may be reduced around that time, but it'll still be a lower priority than gaming, so shouldn't cause the increase in latency that you've been seeing.
Will be interesting to see tonights results.
30-04-2009 10:10 AM
30-04-2009 10:30 AM
30-04-2009 10:34 AM
which led me to think that the slight increase of the rate limits on the hour of 11pm be it the fixed expected limits or the intellegent side of the traffic managment raising the rate limits causing the spikes for short period
was it patch tuesday when i saw lag in cod waw from 9pm onwards
how will know the order has completed as iam not sure if it would resync as theres no upsync on this add on
30-04-2009 9:19 PM
the eleveted weight seems to have made things worse if any thing
now its got to evening and they are shocking iam not even going to power the xbox up there that shocking.
jameseh I AM A GAMER GET ME OUT OF HERE back to lovely jubble ipstream land plz
30-04-2009 9:26 PM
but lasts for an hour or 2 when it kicks of at midnight.
still stands jameseh i want out this madness
would other trialist plz check if there seeing this latency problem plz the cmd to run the ping to the gateway is
ping -t 195.166.128.93
and to stop it crtl+c
thanks
30-04-2009 9:53 PM
so james if you can whack an order into tomoro or today depending when you read this i might just be able to use my xbox by the end of next week
cheers
