I can't use the BT Speedtest
- I can't use the BT Speedtest
02-08-2011 11:51 PM
The BT Speedtest site keeps returning an error. I have followed all instructions. Closed all apps, connected directly to my FTTC router via PPoE, re-installed Java.
Is anyone else having the same problem?
Message 1 of 8
(1,764 Views)
7 REPLIES 7
Re: I can't use the BT Speedtest
02-08-2011 11:59 PM
I gave up trying to use BT speedtest, it kept throwing me out too.
Use
http://www.speedtest.net/
instead
Quick and easy.
until
http://www.mybroadbandspeed.co.uk/
comes back online.
Use
instead
Quick and easy.
until
comes back online.
Message 2 of 8
(741 Views)
03-08-2011 12:03 AM
There may be a valid reason why the BT speedtest needs to be run. All other tests won't tell you your profile for instance.
BT FTTC speedtest working fine for me. Be aware that the speedtest is very unpredictable and can work sometimes and not others. It is how it has always been. Try again tomorrow.
Message 3 of 8
(741 Views)
03-08-2011 1:08 AM
Quote from: Peter There may be a valid reason why the BT speedtest needs to be run. All other tests won't tell you your profile for instance.
Yes, you're right - I do need the stats that only the BT test gives. I have been trying every day since the 26/7 when my FTTC was installed and no joy. Can't get any stats from modem as it is locked by BT, and not buying one just for stats.
What are you doing to get it to work? is it IE9?
Message 4 of 8
(741 Views)
03-08-2011 11:49 AM
Hi Jezzerash,
Do you have the latest version of Java installed?
Jojo
Jojo
Message 5 of 8
(741 Views)
04-08-2011 12:34 AM
Firefox 5 with latest JRE installed.
Also works with IE7, again using the latest JRE
Message 6 of 8
(741 Views)
04-08-2011 8:56 AM
Also works with google chrome. I had limited success with the other browsers.
Message 7 of 8
(741 Views)
04-08-2011 9:50 AM
The BT Speedtester kills Firefox 5.0 on Ubuntu 11.04 here, with whatever the last official Ubuntu version of Java is. I'm also having issues with the software centre and haven't had any Ubuntu updates for at least a fortnight.
Might be time for a fresh install...
Message 8 of 8
(741 Views)
