How to display the router home page
- How to display the router home page
Re: How to display the router home page
09-07-2011 2:03 PM
Wilf
09-07-2011 2:06 PM
09-07-2011 2:12 PM
09-07-2011 2:16 PM
It would be interesting to know if anyone with a Thomson router that doesn't have this fault, whether they can browse the homepage using https://192.168.1.254 ; ?
09-07-2011 2:26 PM
Wilf
11-07-2011 4:29 PM
Quote from: wilf21 Thinking back to when this happened. I had been using a D-Link router for some considerable time and the Thomson router hadn't been used for many months. A few days after being upgraded to ADSL+ (in March this year) the D-Link router failed (I don't know if that's significant) and I took out the Thomson router. Unlike previously, when I used the Thomson before, I could not now access its configuration page in the usual way and it was then that I somehow discovered that I could access it via HTTPS. Other than that, there is nothing obviously strange about the Thomson router and it has been working perfectly since the end of March.
Wilf
Hi Wilf,
That's very interesting... I'd be interested in seeing the output to the commands
:service system list name HTTP expand enabled
and
:service system list name HTTPs expand enabled
I expect the HTTP service will be disabled for some reason.
It can be enabled via:
:service system modify name HTTP state enabled port 80
:service system ifadd name HTTP group lan
Don't add it to the wan interface unless you're looking to attract unwanted visitors!
Hopefully I'm not taking this thread too far off topic.
11-07-2011 4:46 PM
{admin}=>service system list name HTTP expand enabled
Idx Name Protocol SrcPort DstPort Group
1 HTTP tcp 80
Description................ HTTP web server
Properties................. server
Attributes................. state port aclip aclif aclifgroup map log q
oslabel routelabel natpmweight
User Managed Attributes.... state port aclip aclif aclifgroup map log n
atpmweight
Attribute Values :
State...................... (administratively) disabled
Port....................... 80
QOS Label.................. None
Route Label................ None
NAT Portmap Weight ........ 30
Ip Access List............. any
Interface Access List...... any
Interface Group Access List lan
Map List................... 80
Logging.................... disabled
{admin}=>:service system list name=HTTPs expand enabled
1 HTTPs tcp 443
Description................ HTTP web server over ssl
atpmweight
Attribute Values :
State...................... enabled
Port....................... 443
Map List................... 443
{admin}=>service system modify name HTTP state enabled port 80
As you guessed, HTTP was disabled. How? I've no idea.
Now I can get to the Router using HTTP !!!!
I hope this may help the OP.
Many, many thanks, Matt.
Wilf
11-07-2011 5:16 PM
Quote from: purleigh Just hope it works for 'DynaUK'
It would be interesting to know if anyone with a Thomson router that doesn't have this fault, whether they can browse the homepage using https://192.168.1.254 ?
Hello Chaps
Firstly, https://192.168.1.254 doesn't work.
i have checked all the proxy server settings in the browser and there is nothing set. I have even installed Google Chrome & tried in it as I thought it could be something tricky with the browser - FF & IE but still no luck.
Another important thing which I forgot to mention is that I have to connect to AT&T client to get full access to the internet.
If I am outside AT&T, i cannot connect to the internet.
I have also found that pinging external sites takes a long time (>2 mts) to get a response back whereas pinging to the router responds faster. (This is with AT&T not connected).
When AT&T Is connected, pinging to external sites & the router are fast as it should be.
I have checked the AT&T connection properties and cannot see anything stopping me from connecting to the Internet without its use.
jim:green blank space removed mod:end
11-07-2011 5:24 PM
11-07-2011 6:14 PM
Quote from: DynaUK I am able to ... connect to the Internet world without any issue
Quote from: DynaUK Another important thing which I forgot to mention is that I have to connect to AT&T client to get full access to the internet.
Quote Version 1.0 of the AT&T Global Network Client for iOS is now available from iTunes.
Description
Enables access to AT&T Wi-Fi hotspots all over the world from your iPhone, iPad or iTouch.
Are you sure your internet connection actually runs via your own router and not some nearby wireless hot spot? If AT&T has reciprocal arrangements with BT maybe you can access the internet via your neighbour's Home Hub (which has the same default IP address of 192.168.1.254)? When you ran ipconfig, how many connections were shown and which one had the default gateway of 192.168.1.254?
11-07-2011 6:28 PM
Quote from: Oldjim Can you check your hosts file and where are you checking the AT&T connection properties
Yes.. I have checked the hosts file and i have only 1 entry in it which is
127.0.0.1 localhost
Regarding AT&T connection settings i am looking in the
"Show Login Properties" Window
Servers option -> Configure -> Use Default Network settings is selected is for address of DNS & WINS servers
11-07-2011 6:33 PM
Quote from: ReedRichards
Description
Hi.. I have checked and can confirm that it is definitely my router. .Only 1 connection is available using ipconfig with the default gateway pointing to 192.168.1.254. I am connecting it through a wired connection and also noted that the neighbor's connections are all encrypted and hence i wouldn't stand a chance on this for sure.. I have quickly checked to see if i am connecting to mine wirelessly and i am pretty sure it is my network.
11-07-2011 7:35 PM
Quote from: DynaUK
By default a BT Home Hub establishes 3 independent wireless networks. Although these are all encrypted, two are for "public" use if you have the right credentials. I'm afraid as I have never been a BT customer I don't know the details of how to connect.
You presumably installed AT&T Client to access wireless networks whilst travelling? So I presume your computer has a wireless adaptor and it is turned on? ipconfig or ipconfig /all should list what each adaptor is connected to but unless you run this command and look quite carefully (or temporarily disable your wireless adaptor) then I don't think you can be sure what network and therefore what router you are connected to.
11-07-2011 7:47 PM
The ipconfig is still pointing to 192.168.1.254 and AT&T is used to connect to my office world..
When I run ipconfig, it does specify the Ethernet Adapter Local Area connection details which includes the router address - 192.168.1.254
jim:quote
11-07-2011 10:36 PM
I'm not familiar with AT&T client, can you explain the procedure you follow. Do you connect to AT&T client before attempting to login to your router? Is the response when you try to connect to the internet without running AT&T client any different from the response you get when you try to connect to your router?
