How do I get my upload speeds uncapped?
- Re: How do I get my upload speeds uncapped?
07-11-2014 8:06 AM
I have tried raising a support question on the website but there is no way to report poor upload speeds
Is anyone from plusnet on this forum and can they help?
07-11-2014 8:16 AM
If you are not sure post the results you get from http://www.dslchecker.bt.com/adsl/adslchecker.welcome
07-11-2014 8:52 AM
BT BROADBAND AVAILABILITY CHECKER
Telephone Number XXXXXXXX on Exchange BOWES PARK is served by Cabinet 17
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
Availability Date
High Low High Low
FTTC Range A (Clean) 55.8 38.1 14.5 8.9 -- Available
FTTC Range B (Impacted) 47.5 27.4 14.5 6.9 -- Available
WBC ADSL 2+ Up to 13.5 -- 12.5 to 15 Available
WBC ADSL 2+ Annex M Up to 13.5 Up to 1 12.5 to 15 Available
ADSL Max Up to 2 -- 2 to 5 Available
WBC Fixed Rate 2 -- -- Available
Other Offerings
FTTP on Demand 330 30 -- Available
Fibre Multicast -- -- -- Available
Copper Multicast -- -- -- Available
07-11-2014 8:55 AM
07-11-2014 8:57 AM
The better news is that fibre is available which would dramatically increase your speeds. I suggest you ring the customer options team on 0800 013 2632 or 0330 123 9197 and see what deal they will offer. You may be pleasantly surprised.
07-11-2014 9:00 AM
07-11-2014 9:16 AM
07-11-2014 9:25 AM
Edit: The maximum you'll pay is £17.49 for 40 down/20 up if your phone is not with Plusnet. If you ring up you'll probably be offered a deal for the first few months for under £10 a month.
07-11-2014 9:39 AM
07-11-2014 9:58 AM
It will cost you nothing to ring up and find out what they will offer you - then decide. To not make the call and find out would be stupidity as you could actually save money.
07-11-2014 10:37 AM
Your upload speed is actually uncapped at the moment. I would expect you to get faster than the current speed though. Can I please ask that you raise a fault report so that our faults team will investigate further.
In regards to fibre, it's well worth it in my opinion.
Thanks,
Tony
07-11-2014 10:56 AM
