Glossary suggestions
Strat
Fixes: 565
Re: Glossary suggestions
Quote from: Jameseh
Appreciate that this isn't a glossary suggestion, but just so you know Strat...
Why not James. It was the second item I wasn't clear about and others may also be the same.
@chilly....sorry for deviating from the tight thread Embarrassed
BTW...Thank you very much gentlemen for explaining Smiley
chillypenguin
Quote from: Strat
Wink I will let it go, maybe we can get a few more suggestions.
petejackson
A bit quiet in here isn't it?  Have you stumbled across a word or phrase either on this site or another that you think we should explain in an 'easy-to-digest' way?
198kHz
Fixes: 41
Quote from: Peter
OK, may I make some noise and proffer the following?
PPPoA  PPPoE  DSLAM  IP Profile  Faceplate filter
Murphy was an optimist
Zen FTTC 40/10 + Digital Voice   FRITZ!Box 7530
BT technician (Retired)
James
I don't see any point in having PPPoA and PPPoE, but can definitely see the value in talking about DSLAMs IP Profile's and Faceplates.
The distinction between the two along with the definition for ATM (along with references to PSTN) might help it stick on folks minds which they need to be choosing when configuring a router.
geewizz
BBCR
Just saw this one on the forums with reference to a new connection. Can anyone shed any light?
edit : context - http://community.plus.net/forum/index.php/topic,68486.msg549898.html#msg549898
pierre_pierre
bobpullen
Fixes: 316
Quote from: geewizz
BBCR
Broadband Customer Reporting.
geewizz
My confusion was due to the context. I tried looking for suitable expansions of the abbreviation and I dismissed Broadband Customer Reporting because the abbreviation was followed by the word report. I suppose it's a bit like "PIN number" being used when the N stands for number.
Thanks for clarifying.
Stewie
BOT
context> The next action on your Help Assistant Question is due on Friday 2nd October at 9:00am. This Question will remain open with the BOT - Line Check Exception until this time.
Huh
Andrew_B
That would be the Broadband Operations Team.
They look after orders for broadband (for new and existing customers who are moving) and home phone.
