Glossary suggestions
- Re: Glossary suggestions
- « Previous
- 1
- 2
- Next »
16-07-2008 6:52 PM
Quote from: Jameseh Appreciate that this isn't a glossary suggestion, but just so you know Strat...
Why not James. It was the second item I wasn't clear about and others may also be the same.
@chilly....sorry for deviating from the tight thread
BTW...Thank you very much gentlemen for explaining
16-07-2008 8:12 PM
Quote from: Strat @chilly....sorry for deviating from the tight thread
I will let it go, maybe we can get a few more suggestions.
15-09-2008 4:03 PM
15-09-2008 11:12 PM
Quote from: Peter A bit quiet in here isn't it?
OK, may I make some noise and proffer the following?
PPPoA PPPoE DSLAM IP Profile Faceplate filter
Zen FTTC 40/10 + Digital Voice FRITZ!Box 7530
BT technician (Retired)
16-09-2008 9:23 AM
16-09-2008 12:59 PM
30-09-2008 4:31 PM
Just saw this one on the forums with reference to a new connection. Can anyone shed any light?
edit : context - http://community.plus.net/forum/index.php/topic,68486.msg549898.html#msg549898
30-09-2008 5:30 PM
30-09-2008 8:16 PM
Quote from: geewizz BBCR
Broadband Customer Reporting.
30-09-2008 9:19 PM
Thanks for clarifying.
07-10-2009 10:06 PM
Quote context> The next action on your Help Assistant Question is due on Friday 2nd October at 9:00am. This Question will remain open with the BOT - Line Check Exception until this time.
08-10-2009 9:48 AM
They look after orders for broadband (for new and existing customers who are moving) and home phone.
- « Previous
- 1
- 2
- Next »
