Getting Faster
- Re: Getting Faster
Getting Faster
01-06-2013 5:06 PM
It seems that most customers on this forum have speed problems but I must say I am now getting 12 Mb download this is a first time for me because it is around just over 7Mb on average I'm not complaining but I wonder why this as happened I have not changed anything at this end ,is there a explanation.
Message 1 of 6
(990 Views)
5 REPLIES 5
Re: Getting Faster
01-06-2013 6:04 PM
Perhaps you've been upgraded to ADSL2+? Although if you were on 7Mb on ADSLMax you should get much better than 12Mb on ADSL2+.
Can you post the DSL stats from your router?
Message 2 of 6
(491 Views)
Re: Getting Faster
01-06-2013 6:35 PM
THOMSON
Thomson Gateway
Broadband Connection
DSL Connection
Internet Services
Toolbox
Home Network
[ Administrator ] Overview | Details | Help
Home > Broadband Connection > DSL Connection
Physical Connectivity OK
DSL Connection
Link Information
Uptime: 6 days, 23:43:33
DSL Type: G.992.5 annex A
Bandwidth (Up/Down) [kbps/kbps]: 1,163 / 11,239
Output Power (Up/Down) [dBm]: 12.0 / 0.0
Line Attenuation (Up/Down) [dB]: 12.5 / 29.5
SN Margin (Up/Down) [dB]: 6.5 / 3.0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 29 / 0
FEC Errors (Up/Down): 4,294,967,264 / 0
CRC Errors (Up/Down): 4,294,967,264 / 6,350
HEC Errors (Up/Down): 0 / 4,534
Pick a task...
See information about my broadband connection(s)
I hope this information is what you asked me for being a elderly gent not great with all these figures
Message 3 of 6
(491 Views)
Re: Getting Faster
02-06-2013 12:43 AM
Well, you're definitely on ADSL2+, but it's impossible to say if you were on ADSLMax when you were getting 7Mb.
I'd say don't worry about it - sit back and enjoy the improvement
Message 4 of 6
(491 Views)
Re: Getting Faster
02-06-2013 1:10 AM
Yes it is, he was, see his previous posts
valart, the problem really is that as you didn't post back to the thread you started in the middle of May, no-one got round to telling you to check your Current Line speed (Login required). This should equal the BT IP profile from the BTw Diagnostic Speedtest.
If your Current Line Speed is too low it will limit your download speed.
When your Sync speed (Bandwidth Down) changes, so does your Profile and the Current Line speed should change to match it, but because of system bugs it doesn't always do so.
Your current sync speed is 11239kbps which will give a profile of 9.91Mbps and a Current Line Speed of 9.9Mbps. This is the fastest download speed you might get at this time.
Message 5 of 6
(491 Views)
Re: Getting Faster
03-06-2013 5:09 PM
Current line speed on our side is currently set to 9900 so should be spot on
Message 6 of 6
(491 Views)
